Up to 20% off select tools
Euhomy IM-06D Compressor Relay Replacement
View statistics:
Past 24 Hours:
7
Past 7 Days:
28
Past 30 Days:
138
All Time:
878
Comments: 0
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 10 minutes
Difficulty: Moderate
Needs More Images
A few more images would make this guide's procedures crystal clear.
Tools
Introduction
Go to step 1 ↓
This guide is for the Euhomy IM-06D icemaker. This guides purpose is to replace the compressor relay. This part helps create the ice along with the compressor itself. Some symptoms that mean this part may need to be replaced are if the machine is not making ice and is otherwise working as intended. If this is the case, then the compressor relay may need to be replaced. Please make sure to unplug the device before starting all guides.
    1. Euhomy IM-06D Compressor Relay Replacement, Fan: step 1, image 1 of 1
      • Rotate the device so that the screws on the bottom are visible.
      • Remove the two 15 mm Phillips screws.
      • Remove the two 10 mm Phillips screws.
      Ask FixBot
    2. Euhomy IM-06D Compressor Relay Replacement: step 2, image 1 of 2 Euhomy IM-06D Compressor Relay Replacement: step 2, image 2 of 2
      • Remove the back panel from the device.
      Ask FixBot
    3. Euhomy IM-06D Compressor Relay Replacement: step 3, image 1 of 1
      • Remove the two 10 mm Phillips screws that secure the fan.
      Ask FixBot
    4. Euhomy IM-06D Compressor Relay Replacement: step 4, image 1 of 2 Euhomy IM-06D Compressor Relay Replacement: step 4, image 2 of 2
      • Remove the cover plate.
      Ask FixBot
    5. Euhomy IM-06D Compressor Relay Replacement: step 5, image 1 of 2 Euhomy IM-06D Compressor Relay Replacement: step 5, image 2 of 2
      • Snip the zip tie holding the wires together.
      • Unplug the wire from the board.
      • Remove the fan from the device.
      Ask FixBot
    1. Euhomy IM-06D Compressor Relay Replacement, Compressor Relay: step 6, image 1 of 3 Euhomy IM-06D Compressor Relay Replacement, Compressor Relay: step 6, image 2 of 3 Euhomy IM-06D Compressor Relay Replacement, Compressor Relay: step 6, image 3 of 3
      • Locate the black box under the green ground cable and find the silver clip running across the back of it.
      • Use a pry tool remove the clip.
      • Remove the box.
      Ask FixBot
    2. Euhomy IM-06D Compressor Relay Replacement: step 7, image 1 of 3 Euhomy IM-06D Compressor Relay Replacement: step 7, image 2 of 3 Euhomy IM-06D Compressor Relay Replacement: step 7, image 3 of 3
      • Locate the white wire and black relay.
      • Using your hands pull the wire and relay out of the compressor.
      • Once the relay and white wire have been removed you're ready to replace it with your new part.
      Ask FixBot
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
2 other people completed this guide.
Author
with
Brady C
222 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 7
Past 7 Days: 28
Past 30 Days: 138
All Time: 878
