Eufy RoboVac 11+ Battery Replacement
    1. Eufy RoboVac 11+ Battery Replacement, Remove dust tray and brushes: step 1, image 1 of 3 Eufy RoboVac 11+ Battery Replacement, Remove dust tray and brushes: step 1, image 2 of 3 Eufy RoboVac 11+ Battery Replacement, Remove dust tray and brushes: step 1, image 3 of 3
      • Turn off Vacuum using switch on side.
      • Remove dust tray by pressing button and pulling out.
      • Remove center brush using 2 tabs to lift up door, then lift out brush assembly.
      • Remove 2 side brushes with PH #2 screwdriver
      • Brush removal may not be necessary to complete job, but makes it easier to handle the device while working.
      Ask FixBot
    2. Eufy RoboVac 11+ Battery Replacement, Remove bumper: step 2, image 1 of 3 Eufy RoboVac 11+ Battery Replacement, Remove bumper: step 2, image 2 of 3 Eufy RoboVac 11+ Battery Replacement, Remove bumper: step 2, image 3 of 3
      • Remove the 6 PH1 screws securing the lower bumper retaining bracket and remove bracket.
      • Pull bumper forward carefully, as there is a cable connected to it.
      • Unplug the front bumper sensor cable and remove bumper
      Ask FixBot
    3. Eufy RoboVac 11+ Battery Replacement, Case screw locations and removal: step 3, image 1 of 2 Eufy RoboVac 11+ Battery Replacement, Case screw locations and removal: step 3, image 2 of 2
      • Use a screwdriver or pry tool to pop the front small wheel out
      • Remove the PH2 screw hidden below.
      • Remove the remaining 6 PH2 Screws holding the case together.
      Ask FixBot
    4. Eufy RoboVac 11+ Battery Replacement, Cut foam bumpertape: step 4, image 1 of 2 Eufy RoboVac 11+ Battery Replacement, Cut foam bumpertape: step 4, image 2 of 2
      • There are foam tape bumper stops that maybe sealing the case. Do not attempt to remove them. They should be carefully cut at the seam and left in place.
      Ask FixBot
    5. Eufy RoboVac 11+ Battery Replacement, Unplug top button cable: step 5, image 1 of 1
      • There is a cable connecting the top button board to the logic board, lift the case up carefully and unplug. The cable is fitted very tightly, you can carefully work down the side of it with a pry tool and work it out.
      • Alternatively, you can remove the 4x PH2 screws retaining the button board to the top.
      Ask FixBot
    6. Eufy RoboVac 11+ Battery Replacement, Unplug and lift up logic board: step 6, image 1 of 2 Eufy RoboVac 11+ Battery Replacement, Unplug and lift up logic board: step 6, image 2 of 2
      • The logic board should be fully exposed now.
      • Unplug the 9 marked connectors on the logic board to create enough slack to lift it up.
      • You can also unplug all connectors and remove board completely for better access.
      • When working under the logic board, try not to disturb the disconnected cables to much, so they won't get tangled or mixed up. When reinstalling, be careful not to pinch any wires between the logic board and rest of device.
      • Unscrew 4x PH2 screws retaining the logic board.
      Ask FixBot
    7. Eufy RoboVac 11+ Battery Replacement, Replace battery: step 7, image 1 of 3 Eufy RoboVac 11+ Battery Replacement, Replace battery: step 7, image 2 of 3 Eufy RoboVac 11+ Battery Replacement, Replace battery: step 7, image 3 of 3
      • Lift up or remove logic board, and remove the PH1 screw retaining the battery cover.
      • Disconnect the battery. Depending on the type of plug used, it may have clips or just be pressed together tightly.
      • Work/wiggle the battery out of its holder. Using a spudger or similar pry tool to lift up on the bottom edge of the battery can help.
      Ask FixBot
    8. Eufy RoboVac 11+ Battery Replacement, Battery plug variations: step 8, image 1 of 1
      • There are different styles of battery connectors that maybe used. Although the battery I ordered was listed as compatible, it came with a different connector. I soldered/spliced the old connector onto my new battery.
      Ask FixBot
Eric Essen
18,333 Reputation
9 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 11
Past 30 Days: 64
All Time: 247
