Eufy Clean RoboVac G32 Pro Battery Replacement
    1. Eufy Clean RoboVac G32 Pro Battery Replacement, Battery: step 1, image 1 of 1
      • Make sure your device is turned off.
      • Flip the device upside down on a flat surface.
      Ask FixBot
    2. Eufy Clean RoboVac G32 Pro Battery Replacement: step 2, image 1 of 1
      • Remove two 10 mm screws using a Phillips #1 screwdriver.
      Ask FixBot
    3. Eufy Clean RoboVac G32 Pro Battery Replacement: step 3, image 1 of 1
      • Lift the cover of the battery.
      Ask FixBot
    4. Eufy Clean RoboVac G32 Pro Battery Replacement: step 4, image 1 of 1
      • Lift up the battery using the white straps on the side.
      Ask FixBot
    5. Eufy Clean RoboVac G32 Pro Battery Replacement: step 5, image 1 of 2 Eufy Clean RoboVac G32 Pro Battery Replacement: step 5, image 2 of 2
      • While holding the battery, pinch the clips on the side of the white connector.
      • Using a spudger, push the part of the connector inside of the Robovac away from the white connector on the battery.
      • Pinch the clips hard; they may be a little stiff.
      • Remove the battery from the device.
      Ask FixBot
Cassandra Arencibia
266 Reputation
1 Guide authored
Marist, Team 1-4, Chaterdon Spring 2023 Member of Marist, Team 1-4, Chaterdon Spring 2023
MARS-CHATERDON-S23S1G4
4 Members
48 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 22
Past 30 Days: 63
All Time: 1,945
