Eton FRX5-BT Case Disassembly
  1. Eton FRX5-BT Case Disassembly, Remove plastic cap: step 1, image 1 of 1
    • Press on the left most side on the small plastic cap on the back of the radio (it is loosely glued in place).
    • When the plastic cap comes loose, remove it completely to access the lock mechanism below.
    Ask FixBot
  2. Eton FRX5-BT Case Disassembly, Remove the solar panel: step 2, image 1 of 1
    • Slide the lock mechanism all the way to the left. Now the solar panel is no longer locked in place.
    • Remove the solar panel, by lifting it on the top part. You can use a suction cup or carefully tilt the device when it's in an upright position.
    • Be mindful on the wire connecting the solar panel to the rest of the device.
    Ask FixBot
  3. Eton FRX5-BT Case Disassembly, Remove screws: step 3, image 1 of 1
    • Remove the six 2.5mm Hex screws.
    Ask FixBot
  4. Eton FRX5-BT Case Disassembly, Open the case: step 4, image 1 of 1
    • Pull the two halves of the device case apart.
    • There are no wires connecting the two parts of the case, but the solar panel wire goes through a hole in the back case and connects it to the rest of the device.
    Ask FixBot
2 other people completed this guide.
Martin
184 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 9
Past 30 Days: 54
All Time: 783
