Eton FRX3 Rechargeable Battery Pack Replacement
  1. Eton FRX3 Rechargeable Battery Pack Replacement, Rechargeable Battery Pack: step 1, image 1 of 1
    • Pull the plastic tab on the battery compartment cover panel to loosen it, then pull the panel off.
    Ask FixBot
  2. Eton FRX3 Rechargeable Battery Pack Replacement: step 2, image 1 of 1
    • Disconnect the battery pack wires from the device and remove the battery pack.
    Ask FixBot
To reassemble your device, follow these instructions in the reverse order.
3 other people completed this guide.
Kenneth Sills
762 Reputation
6 Guides authored
USF Tampa, Team 1-6, Nance Spring 2016 Member of USF Tampa, Team 1-6, Nance Spring 2016
USFT-NANCE-S16S1G6
4 Members
13 Guides authored
4 Guide Comments
My question is where can you find an FRX3 replacement battery?
jalwitt - Reply Share
Hey mate, you can buy the battery packs from a number of sources. Here's the link to one of those sources https://www.amazon.com/HQRP-FR200-BAT-3A...
james - Reply Share
is it ok to replace it with a higher capacity lithium battery?
troydeleon - Reply Share
As long as the specifications match, that should be fine. Just be careful when swapping out components in circuits, as it can potentially destroy the device if they're incompatible!
Kenneth Sills - Reply Share
Past 24 Hours: 5
Past 7 Days: 12
Past 30 Days: 74
All Time: 6,598
