Up to 20% off select tools
Ethernet Diagnostics Port
Views: 1.3K
View statistics:
Past 24 Hours:
2
Past 7 Days:
16
Past 30 Days:
94
All Time:
1,255
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 1 minute
Difficulty: Easy
In Progress
This guide is a work in progress. Reload periodically to see the latest changes!
Community-Contributed Guide
      • The ethernet diagnostics port is located behind the drivers side instrument panel cover.
      • The plastic panel is secured by 3 metal flex trim clips. Using an appropriate pry tool pry backwards at the points indicated
      Ask FixBot
      • After opening the side panel, hold onto the cover until you disconnect the key fob antenna connector. Failure to do so could cause excessive strain on the wiring
      • Reach into the opening to feel for the diagnostic cable, if you have never had the car serivced it may be tucked down into the recess
      • There should only be one cable with a circular white connector
      Ask FixBot
      • Pull out the connector, but be careful, since there is not much slack in the cable. This is part of a large and expensive wiring harness.
      • Connect the FakraHSD to Ethernet cable until you hear a click.
      • To disconnect press down on the small finger and gently pull the connectors apart.
      Ask FixBot
Author
with
obrien28
571 Reputation
2 Guides authored
iMaster Repairs Member of iMaster Repairs
Business
1 Member
24 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 16
Past 30 Days: 94
All Time: 1,255
