Escort Passport Max2 Lens Replacement
View statistics:
Past 24 Hours:
0
Past 7 Days:
12
Past 30 Days:
56
All Time:
825
Comments: 2
1 comment on steps, 1 guide comment.
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 10 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
If the Passport Max2's lens gets cracked or damaged, this guide will communicate how to replace it.
Tools
  • Spudger
    4.9
  • Phillips #1 Screwdriver
    5
    1. Escort Passport Max2 Lens Replacement, Exterior Case: step 1, image 1 of 2 Escort Passport Max2 Lens Replacement, Exterior Case: step 1, image 2 of 2
      • Inser the flat end of a spudger into one of the two notches and pry off the case.
      Ask FixBot
    2. Escort Passport Max2 Lens Replacement: step 2, image 1 of 2 Escort Passport Max2 Lens Replacement: step 2, image 2 of 2
      • Slide the spudger around the perimeter of the radar housing until the case separates.
      Ask FixBot
    3. Escort Passport Max2 Lens Replacement: step 3, image 1 of 2 Escort Passport Max2 Lens Replacement: step 3, image 2 of 2
      • Repeat these steps to remove the other side.
      Ask FixBot
    1. Escort Passport Max2 Lens Replacement, Lens: step 4, image 1 of 2 Escort Passport Max2 Lens Replacement, Lens: step 4, image 2 of 2
      • Remove the four 9mm Phillips #1 screws from the bottom of the radar.
      • Remove the bottom case.
      Ask FixBot
    2. Escort Passport Max2 Lens Replacement: step 5, image 1 of 1
      • Gently spread apart the thin silver frame that wraps around the device and remove the dark purple lens.
      • The silver frame can easily pop off of the device now that the bottom metal case has been removed. Don't worry if it comes off all the way. It can easily be put back in it's place.
      Ask FixBot
Kelsey Ferrenberg
770 Reputation
4 Guides authored
UW Tacoma, Team S1-G1, Liner Spring 2018 Member of UW Tacoma, Team S1-G1, Liner Spring 2018
UWT-LINER-S18S1G1
5 Members
48 Guides authored
1 Guide Comment
Where can I buy a replacement lens?
Kit - Reply Share
Past 24 Hours: 0
Past 7 Days: 12
Past 30 Days: 56
All Time: 825
