Escort Passport 9500IX Display Replacement
Views: 2.7K
View statistics:
Past 24 Hours:
Past 7 Days:
14
Past 30 Days:
76
All Time:
2,693
Comments: 2
2 comments on steps.
Completed: 0
Favorites: 0
Time Required: 8 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
Is your radar's display not powering on or just hangs on a black screen? If this is the case, then the display could be at fault. Follow this guide to replace the display on your radar.
Tools
  • Phillips #1 Screwdriver
    5
  • Spudger
    4.9
    1. Escort Passport 9500IX Display Replacement, Back Panel: step 1, image 1 of 1
      • Remove the three 1.2 mm Phillips #1 screws on the back of the device.
      Ask FixBot
    2. Escort Passport 9500IX Display Replacement: step 2, image 1 of 1
      • Pry off the back panel of the radar using the nylon spudger.
      Ask FixBot
    1. Escort Passport 9500IX Display Replacement, Display: step 3, image 1 of 3 Escort Passport 9500IX Display Replacement, Display: step 3, image 2 of 3 Escort Passport 9500IX Display Replacement, Display: step 3, image 3 of 3
      • Carefully pry the grey frame off the black plastic covering using the nylon spudger.
      Ask FixBot
    2. Escort Passport 9500IX Display Replacement: step 4, image 1 of 3 Escort Passport 9500IX Display Replacement: step 4, image 2 of 3 Escort Passport 9500IX Display Replacement: step 4, image 3 of 3
      • Detach the orange flap from the motherboard using a nylon spudger.
      • Carefully remove the motherboard from the grey plastic frame.
      Ask FixBot
    3. Escort Passport 9500IX Display Replacement: step 5, image 1 of 2 Escort Passport 9500IX Display Replacement: step 5, image 2 of 2
      • Detach the remaining two orange flaps from the circuit board that is attached onto the grey frame.
      Ask FixBot
    4. Escort Passport 9500IX Display Replacement: step 6, image 1 of 2 Escort Passport 9500IX Display Replacement: step 6, image 2 of 2
      • Detach the display from the grey frame.
      Ask FixBot
Jiahao Xu
195 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 14
Past 30 Days: 76
All Time: 2,693
