Up to 20% off select tools
Escort Passport 9500IX Button Replacement
Views: 1.3K
View statistics:
Past 24 Hours:
5
Past 7 Days:
20
Past 30 Days:
72
All Time:
1,338
Comments: 3
2 comments on steps, 1 guide comment.
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 5 minutes
Difficulty: Easy
Tools
  • Phillips #1 Screwdriver
    5
  • Spudger
    4.9
Introduction
Go to step 1 ↓
Are the buttons on your Escort Radar 9500IX's cracked or jammed? If this is the case, then follow this guide to replace the buttons on your radar.
    1. Escort Passport 9500IX Button Replacement, Back Panel: step 1, image 1 of 1
      • Remove the three 1.2 mm Phillips #1 screws on the back of the device.
      Ask FixBot
    2. Escort Passport 9500IX Button Replacement: step 2, image 1 of 1
      • Pry off the back panel of the radar using the nylon spudger.
      Ask FixBot
    1. Escort Passport 9500IX Button Replacement, Buttons: step 3, image 1 of 3 Escort Passport 9500IX Button Replacement, Buttons: step 3, image 2 of 3 Escort Passport 9500IX Button Replacement, Buttons: step 3, image 3 of 3
      • Carefully pry the grey frame off the black plastic covering using the nylon spudger.
      Ask FixBot
    2. Escort Passport 9500IX Button Replacement: step 4, image 1 of 2 Escort Passport 9500IX Button Replacement: step 4, image 2 of 2
      • Slowly peel the buttons off the button board.
      Ask FixBot
Author
with
Kennedy Morales
664 Reputation
6 Guides authored
1 Guide Comment
Ummm where/how do you get the replacement buttons.  Mine are just simply non legible from wear and tear, yet still works perfectly.
mike videtto - Reply Share
Past 24 Hours: 5
Past 7 Days: 20
Past 30 Days: 72
All Time: 1,338
