Equity Alarm Clock 13014 Alarm Switch Replacement
Views: 2.2K
View statistics:
Past 24 Hours:
3
Past 7 Days:
28
Past 30 Days:
114
All Time:
2,222
Comments: 0
Go to guide comments
Completed: 3
3 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 25 - 40 minutes
Difficulty: Difficult
Introduction
Go to step 1 ↓
If the alarm on your Equity Alarm Clock 13014 is not going off, use this guide to replace the alarm switch.
The alarm switch is a small lever that is flipped, at the set time of the alarm, to activate an internal circuit which in response triggers the alarm to sound. A faulty alarm switch will not activate the internal circuit therefore, never triggering the sound.
Step 5 requires knowledge of basic soldering to detach a wire.
Here is a helpful video on basic soldering: How To Solder and Desolder Connections
Tools
    1. Equity Alarm Clock 13014 Alarm Switch Replacement, Replacing the alarm switch: step 1, image 1 of 3 Equity Alarm Clock 13014 Alarm Switch Replacement, Replacing the alarm switch: step 1, image 2 of 3 Equity Alarm Clock 13014 Alarm Switch Replacement, Replacing the alarm switch: step 1, image 3 of 3
      • Remove the battery door using your finger nail or an opening tool.
      Ask FixBot
    2. Equity Alarm Clock 13014 Alarm Switch Replacement, Remove screws: step 2, image 1 of 2 Equity Alarm Clock 13014 Alarm Switch Replacement, Remove screws: step 2, image 2 of 2
      • Use a Phillips #1 screwdriver to remove the 3 screws on the back cover.
      Ask FixBot
    3. Equity Alarm Clock 13014 Alarm Switch Replacement, Remove Cover: step 3, image 1 of 1
      • Remove the back cover gently.
      • DO NOT pull the back cover off quickly or you may damage the wires connected.
      Ask FixBot
    4. Equity Alarm Clock 13014 Alarm Switch Replacement: step 4, image 1 of 2 Equity Alarm Clock 13014 Alarm Switch Replacement: step 4, image 2 of 2
      • Use a Phillips #1 screwdriver to remove the small screw located above the alarm switch.
      • Remove the small screw located below the alarm switch as well.
      Ask FixBot
    5. Equity Alarm Clock 13014 Alarm Switch Replacement: step 5, image 1 of 2 Equity Alarm Clock 13014 Alarm Switch Replacement: step 5, image 2 of 2
      • Place the end of the soldering iron on the end of the wire connected to the copper cylinder to detach the wire.
      • If you are unfamiliar with soldering, take a look at this article: How to Solder and Desolder Connections.
      • To replace the alarm switch, attach one end of new alarm switch wire to the copper cylinder.
      • Use a Phillips #1 screwdriver to reinstall the switch screws.
      • Follow steps in reverse order to assemble the clock.
      Ask FixBot
3 other people completed this guide.
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 28
Past 30 Days: 114
All Time: 2,222
