Epson XP-220 Ink Cartridge Replacement
      • If the printer is out of ink (one or more cartridges), the ink light under the orange button will light up orange.
      • If it's low on ink, the light will blink.
      Ask FixBot
    1. Epson XP-220 Ink Cartridge Replacement: step 2, image 1 of 2 Epson XP-220 Ink Cartridge Replacement: step 2, image 2 of 2
      • Lift up the top half of the printer to open it.
      • Todo: better photos here
      Ask FixBot
    2. Epson XP-220 Ink Cartridge Replacement: step 3, image 1 of 2 Epson XP-220 Ink Cartridge Replacement: step 3, image 2 of 2
      • Push the orange button to make the print head move. It will park the empty cartridge behind the plastic arrow to indicate it needs replacing.
      • It won't move if all the cartridges are good.
      • Push the button again. If more than one cartridge is empty, the printer will indicate the next one.
      • When the printer has shown all the empty cartridges, push the orange button to move the print head to the cartridge changing bay.
      • This handy little diagram is stamped in the printer.
      Ask FixBot
      • Grab the empty cartridge by the front and back and squeeze it gently to release the latch.
      • Pull it out and then repeat for any other empty cartridges.
      • Optional: If you haven't used the printer in a while, shake the cartridges and put them back in, to make sure they really are empty. Push the orange button to make the printer check them again.
      Ask FixBot
      • Shake the new cartridge(s) well to mix the ink.
      • The printer will complain if the ink settles and gets stuck in the cartridge.
      • Peel off the labelled factory seal.
      • Push the cartridge down into its slot until it clicks.
      • Push the orange button to make the printer check the new cartridges.
      Ask FixBot
    3. Epson XP-220 Ink Cartridge Replacement: step 6, image 1 of 2 Epson XP-220 Ink Cartridge Replacement: step 6, image 2 of 2
      • When the ink light goes out, the printer is ready to work. Free the grey plastic latch to close it.
      • This handy diagram is stamped near the latch.
      Ask FixBot
If the printer won't recognise a fresh cartridge, take out the cartridge and shake it again.
Sparky
1,731 Reputation
12 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 14
Past 30 Days: 44
All Time: 82
