Epson VS250 Speaker Replacement
  1. Epson VS250 Speaker Replacement, Shell: step 1, image 1 of 1
    • Place the projector on a flat surface.
    • Orient the projector so that the the word "Epson" is facing you.
    • Using the Phillips #1 screwdriver, to loosen the screw on the top right corner of the projector. The screw only needs to be loosened.
    Ask FixBot
  2. Epson VS250 Speaker Replacement: step 2, image 1 of 1
    • Slide the cover to the right and lift the cover up and out to remove.
    Ask FixBot
  3. Epson VS250 Speaker Replacement: step 3, image 1 of 1
    • Using a Phillips #1 screwdriver, remove the three 6 mm screws that hold the side portion of the projector in place.
    • Use the same Phillips #1 screwdriver to remove the single 10 mm screw that is holding the side cover of the projector in place.
    Ask FixBot
  4. Epson VS250 Speaker Replacement: step 4, image 1 of 1
    • Use a Phillips #1 screwdriver to remove the two 10 mm screws that are holding the side cover of the projector in place.
    Ask FixBot
  5. Epson VS250 Speaker Replacement: step 5, image 1 of 2 Epson VS250 Speaker Replacement: step 5, image 2 of 2
    • Flip the projector so that it lays upside down.
    • Using a Phillips #1 screwdriver, remove the eight 10 mm screws that secure the side portion of the projector.
    Ask FixBot
  6. Epson VS250 Speaker Replacement: step 6, image 1 of 1
    • Remove the front cover from the projector by pulling it off of the device.
    Ask FixBot
  7. Epson VS250 Speaker Replacement: step 7, image 1 of 1
    • Use a Phillips #1 screwdriver to remove the two 10 mm screws.
    • After completing this step you will be able to remove the back cover from the projector.
    Ask FixBot
  8. Epson VS250 Speaker Replacement: step 8, image 1 of 1
    • Slowly lift up the top shell up and out of the device.
    • Disconnect the ribbon cable from the motherboard and remove the shell from the device.
    Ask FixBot
  9. Epson VS250 Speaker Replacement, Speaker: step 9, image 1 of 1
    • Use a Phillips #1 screwdriver to remove the two 10 mm screws holding the speaker in place.
    Ask FixBot
  10. Epson VS250 Speaker Replacement: step 10, image 1 of 2 Epson VS250 Speaker Replacement: step 10, image 2 of 2
    • Pinch and unplug the speaker cable from the motherboard.
    • Remove the speaker from the device.
    Ask FixBot
Warren Cutlip
604 Reputation
5 Guides authored
Clemson, Team 4-2, Hunter Fall 2021 Member of Clemson, Team 4-2, Hunter Fall 2021
CLEM-HUNTER-F21S4G2
5 Members
5 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 9
Past 30 Days: 53
All Time: 359
