Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Needs More Images
A few more images would make this guide's procedures crystal clear.
Introduction
Go to step 1 ↓Use this guide to replace one or both of the faulty extendable feet on the Epson VS250 projector. The extendable legs help with angling the display image of the projector in order to get it into the correct alignment. If you notice that the display image on the screen is tiled then the legs should be the first components to check. First check that both legs are extended equally to ensure a balanced image. If you find that your Epson VS250 projector’s feet are not extending correctly, or at all, you will need to replace them. If one or both of the legs are damaged then this guide will show you how to replace them.
Place the projector on a flat surface.
Orient the projector so that the the word "Epson" is facing you.
Use Phillips #1 screwdriver to loosen the 10 mm screw on the top right corner of the projector.
Use a Phillips #1 screwdriver to remove the three 6 mm screws that hold the side portion of the projector in place.
