Up to 20% off select tools
Epson VS250 Air Filter Replacement
View statistics:
Past 24 Hours:
Past 7 Days:
13
Past 30 Days:
62
All Time:
753
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 1 - 2 minutes
Difficulty: Very easy
Introduction
Go to step 1 ↓
Use this guide to change the air filter on your Epson VS250 projector. The air filter allows the projector to take in cool air while reducing the amount of dust entering. It is important to keep these dust particles from settling inside the projector because they have the possibility of overheating the projector and creating fire. The air filter is the first thing you should check if the projector is having overheating problems. This replacement guide will teach you how to remove the air filter in the event that you want to clean the current filter or replace it with a new one. If overheating persists, check out the Fan replacement guide.
    1. Epson VS250 Air Filter  Replacement, Air Filter: step 1, image 1 of 1
      • The cover for the air filter can be located at the top left corner of the projector when positioned so that the word "Epson" is facing you.
      • Place your fingers underneath the indented area of the center portion of the filter cover.
      • Once your fingers are aligned simply grip it and pull up to remove.
      Ask FixBot
    2. Epson VS250 Air Filter  Replacement: step 2, image 1 of 1
      • Grip the black tab and pull it directly up to remove the air filter from the device.
      Ask FixBot
Author
with
Warren Cutlip
604 Reputation
5 Guides authored
Clemson, Team 4-2, Hunter Fall 2021 Member of Clemson, Team 4-2, Hunter Fall 2021
CLEM-HUNTER-F21S4G2
5 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 13
Past 30 Days: 62
All Time: 753
