Needs More Images
A few more images would make this guide's procedures crystal clear.
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Tools
Spudger4.9
Introduction
Go to step 1 ↓This guide demonstrates how to replace the stand in the Epson VS240 projector. While the stand is not necessary for the projector to function, if it is damaged it may prove difficult to properly set up the device to project at the exact right angle for it to properly hit the wall/screen at the angle needed to clearly display the image. The stand itself will have to be replaced from another VS240 because the stands are not sold individually. The stand would be important to replace because the stand allows the proper angle to be use to project the image properly onto a surface.
Power down and unplug the projector before beginning.
Using the Phillips #2 screwdriver, loosen the single captive screw on the left side of the projector.
Slide the panel off and remove it from the device.
Using a spudger or a plastic opening tool, disconnect all of the wires connected to the motherboard.
Rotate the projector 180 degrees to match orientation in images.
Using the Phillips #2 screwdriver, remove four inner 11 mm screws under the black box connected to the lens.
Tool used on this step:Tweezers$4.99
Using hook nose tweezers, break off the two large prongs that are located at the left and right of the stand at the very top.
Gently raise the front of the projector and push the tab that adjusts the stand upwards. This shall result in the stand extending out of the base of the projector.
If the stand does not entirely slide out of the base, grab the part of the stand that has been exposed and pull it until you have removed the entire piece from the base.
