Up to 20% off select tools
Epson VS240 Shell Replacement
View statistics:
Past 24 Hours:
2
Past 7 Days:
10
Past 30 Days:
64
All Time:
603
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 10 - 30 minutes
Difficulty: Easy
Needs More Images
A few more images would make this guide's procedures crystal clear.
Tools
Introduction
Go to step 1 ↓
This guide is to assist you in removing the Epson VS240's shell for access into the projector. Removal of the shell will be necessary for any repairs of the eternal components of the projector.
For this repair you will need a screwdriver extender to reach some of the screws.
Be careful for the white ribbon cable in step 7, it is very fragile and you don't want to break it.
    1. Epson VS240 Shell Replacement, Shell: step 1, image 1 of 3 Epson VS240 Shell Replacement, Shell: step 1, image 2 of 3 Epson VS240 Shell Replacement, Shell: step 1, image 3 of 3
      • Using the Phillips #2 screwdriver, loosen the single captive screw on the left side of the projector.
      • The captive screw will loosen, but it cannot be fully removed.
      • Slide the panel off and remove it from the device.
      Ask FixBot
    2. Epson VS240 Shell Replacement: step 2, image 1 of 2 Epson VS240 Shell Replacement: step 2, image 2 of 2
      • Use the Phillips #2 screwdriver to remove the three 5 mm screws.
      • Using the same Phillips #2 screwdriver, remove the single 8 mm silver screw.
      Ask FixBot
    3. Epson VS240 Shell Replacement: step 3, image 1 of 1
      • Use a Phillips #1 screwdriver to remove the two 10 mm silver screws from the bottom of the device.
      Ask FixBot
    4. Epson VS240 Shell Replacement: step 4, image 1 of 1
      • Use a Phillips #1 screwdriver to remove the single 10 mm screw where the panel was removed in Step 1.
      • Remove the white back plate from the device.
      Ask FixBot
    5. Epson VS240 Shell Replacement: step 5, image 1 of 3 Epson VS240 Shell Replacement: step 5, image 2 of 3 Epson VS240 Shell Replacement: step 5, image 3 of 3
      • Flip the projector over so that the underside (side with the feet) is facing you.
      • Use a Phillips #1 screwdriver to remove five 10 mm screws on the underside of projector.
      • Using the same Phillips #1 screwdriver, remove a single 10 mm screw in the center hole.
      • You may need to use a screwdriver extender to reach the single screw.
      Ask FixBot
    6. Epson VS240 Shell Replacement: step 6, image 1 of 3 Epson VS240 Shell Replacement: step 6, image 2 of 3 Epson VS240 Shell Replacement: step 6, image 3 of 3
      • Use a Phillips #1 screwdriver to remove two 10 mm screws from the openings on each side of the air filter, on the topside of the projector.
      • You may need to use a screwdriver extender to reach the two screws.
      • Using the same Phillips #1 screwdriver, remove the two 10 mm screws where the white panel was removed on the topside of the projector in Step 1.
      Ask FixBot
    7. Epson VS240 Shell Replacement: step 7, image 1 of 2 Epson VS240 Shell Replacement: step 7, image 2 of 2
      • Be careful when removing the top cover of projector as there is as white ribbon cable connecting it to the motherboard.
      • Gently lift top cover and place it on its top next to the projector so that the ribbon has no tension on it.
      • Gently pull the brown tape connecting the cable to the motherboard and then remove the shell from the device.
      Ask FixBot
Author
with
Gerard Huber
374 Reputation
2 Guides authored
Clemson, Team 5-3, Hunter Fall 2021 Member of Clemson, Team 5-3, Hunter Fall 2021
CLEM-HUNTER-F21S5G3
5 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 10
Past 30 Days: 64
All Time: 603
