Up to 20% off select tools
Epson VS240 Lens Replacement
View statistics:
Past 24 Hours:
2
Past 7 Days:
12
Past 30 Days:
91
All Time:
775
Comments: 1
1 guide comment.
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 40 minutes - 1 hour
Difficulty: Moderate
Needs More Images
A few more images would make this guide's procedures crystal clear.
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Tools
Introduction
Go to step 1 ↓
If your Epson projector (model VS240) is experiencing display errors such as dark spots, missing regions, or focus issues, you can use this guide to replace the lens.
The lens is a key component of the projector that allows for images and video to be displayed, and a dirty lens or improper display settings can lead to display issues. Before choosing to replace the lens, check for and troubleshoot common display error issues.
Make sure to power off the projector and disconnect it from any external power sources before proceeding.
    1. Epson VS240 Lens Replacement, Shell: step 1, image 1 of 3 Epson VS240 Lens Replacement, Shell: step 1, image 2 of 3 Epson VS240 Lens Replacement, Shell: step 1, image 3 of 3
      • Using the Phillips #2 screwdriver, loosen the single captive screw on the left side of the projector.
      • The captive screw will loosen, but it cannot be fully removed.
      • Slide the panel off and remove it from the device.
      Ask FixBot
    2. Epson VS240 Lens Replacement: step 2, image 1 of 2 Epson VS240 Lens Replacement: step 2, image 2 of 2
      • Use the Phillips #2 screwdriver to remove the three 5 mm screws.
      • Using the same Phillips #2 screwdriver, remove the single 8 mm silver screw.
      Ask FixBot
    3. Epson VS240 Lens Replacement: step 3, image 1 of 1
      • Use a Phillips #1 screwdriver to remove the two 10 mm silver screws from the bottom of the device.
      Ask FixBot
    4. Epson VS240 Lens Replacement: step 4, image 1 of 1
      • Use a Phillips #1 screwdriver to remove the single 10 mm screw where the panel was removed in Step 1.
      • Remove the white back plate from the device.
      Ask FixBot
    5. Epson VS240 Lens Replacement: step 5, image 1 of 3 Epson VS240 Lens Replacement: step 5, image 2 of 3 Epson VS240 Lens Replacement: step 5, image 3 of 3
      • Flip the projector over so that the underside (side with the feet) is facing you.
      • Use a Phillips #1 screwdriver to remove five 10 mm screws on the underside of projector.
      • Using the same Phillips #1 screwdriver, remove a single 10 mm screw in the center hole.
      • You may need to use a screwdriver extender to reach the single screw.
      Ask FixBot
    6. Epson VS240 Lens Replacement: step 6, image 1 of 3 Epson VS240 Lens Replacement: step 6, image 2 of 3 Epson VS240 Lens Replacement: step 6, image 3 of 3
      • Use a Phillips #1 screwdriver to remove two 10 mm screws from the openings on each side of the air filter, on the topside of the projector.
      • You may need to use a screwdriver extender to reach the two screws.
      • Using the same Phillips #1 screwdriver, remove the two 10 mm screws where the white panel was removed on the topside of the projector in Step 1.
      Ask FixBot
    7. Epson VS240 Lens Replacement: step 7, image 1 of 2 Epson VS240 Lens Replacement: step 7, image 2 of 2
      • Be careful when removing the top cover of projector as there is as white ribbon cable connecting it to the motherboard.
      • Gently lift top cover and place it on its top next to the projector so that the ribbon has no tension on it.
      • Gently pull the brown tape connecting the cable to the motherboard and then remove the shell from the device.
      Ask FixBot
    1. Epson VS240 Lens Replacement, Motherboard: step 8, image 1 of 2 Epson VS240 Lens Replacement, Motherboard: step 8, image 2 of 2
      • Using a spudger or a plastic opening tool, disconnect all of the wires connected to the motherboard.
      Ask FixBot
    2. Epson VS240 Lens Replacement: step 9, image 1 of 2 Epson VS240 Lens Replacement: step 9, image 2 of 2
      • Using the Phillips #1 screwdriver, remove three 6 mm screws.
      • Using the same Phillips #1 screwdriver, remove a single 10 mm screw in bottom right corner of motherboard.
      Ask FixBot
    3. Epson VS240 Lens Replacement: step 10, image 1 of 2 Epson VS240 Lens Replacement: step 10, image 2 of 2
      • Using a spudger or your fingernails, lift up the black locking tabs and disconnect the three ribbon cables from the motherboard.
      • For more information on Zero Insertion Force (ZIF) connectors, please visit this guide.
      • Using the Phillips #1 screwdriver, remove three 10 mm screws on the grey piece that is located on the side of the motherboard.
      Ask FixBot
    4. Epson VS240 Lens Replacement: step 11, image 1 of 1
      • Lift and remove the motherboard up and away from the device.
      Ask FixBot
    1. Epson VS240 Lens Replacement, Lens: step 12, image 1 of 2 Epson VS240 Lens Replacement, Lens: step 12, image 2 of 2
      • Rotate the projector 180 degrees to match orientation in images.
      • Using the Phillips #2 screwdriver, remove four inner 11 mm screws under the black box connected to the lens.
      • These screws are located deep into the projector and you may need a screwdriver extender to reach two of the four screws.
      Ask FixBot
    2. Epson VS240 Lens Replacement: step 13, image 1 of 2 Epson VS240 Lens Replacement: step 13, image 2 of 2
      • Detach the wire above the lens using plastic pry bar.
      • These wires can also be removed by hand; however, a plastic opening tool may be used for more prying power.
      • Slowly lift the black assembly out of the device.
      • Be careful of the wire still connected. It does not need to be removed so lay the black assembly close to the projector so no tension is on the wire.
      Ask FixBot
Author
with
Vincent Brown
105 Reputation
1 Guide authored
Clemson, Team 5-3, Hunter Fall 2021 Member of Clemson, Team 5-3, Hunter Fall 2021
CLEM-HUNTER-F21S5G3
5 Members
72 Guides authored
1 Guide Comment
This guide helped me remove the lens assembly and reassemble in about 1 hour. Well done guide.
DFixitGuy - Reply Share
Past 24 Hours: 2
Past 7 Days: 12
Past 30 Days: 91
All Time: 775
