Epson Stylus NX305 Scanner Motor Replacement
    1. Epson Stylus NX305 Scanner Motor Replacement, Scanner Motor: step 1, image 1 of 1
      • Make sure that the printer is not plugged in before working on it.
      • Orient the printer so that the back of it is facing you.
      Ask FixBot
    2. Epson Stylus NX305 Scanner Motor Replacement: step 2, image 1 of 1
      • Locate the 3mm Phillips #0 screw that is on the right-hand side of the printer.
      • Using a Phillips head screwdriver, remove the screw.
      Ask FixBot
    3. Epson Stylus NX305 Scanner Motor Replacement: step 3, image 1 of 2 Epson Stylus NX305 Scanner Motor Replacement: step 3, image 2 of 2
      • Open up the lid of the printer.
      • With the printer facing away from you, lift up on the right hand side of the lid of the printer and slide it to the left to remove it.
      • Be careful not to remove the white ribbon and wires that are connected.
      Ask FixBot
    4. Epson Stylus NX305 Scanner Motor Replacement: step 4, image 1 of 1
      • With the printer facing you, open the lid of the scanner to expose the 3mm Phillips #0 screw at the top left of the scanner.
      Ask FixBot
    5. Epson Stylus NX305 Scanner Motor Replacement: step 5, image 1 of 1
      • Locate the six 3mm Phillips #2 screws under the lid of the printer and remove them.
      Ask FixBot
    6. Epson Stylus NX305 Scanner Motor Replacement: step 6, image 1 of 1
      • Locate the three clips on the front side of the printer lid.
      • Use the plastic opening tool to release the clips and carefully pry open the lid.
      Ask FixBot
    7. Epson Stylus NX305 Scanner Motor Replacement: step 7, image 1 of 1
      • Locate the belt that is attached to the scanner motor and remove it by carefully stretching off of the gear.
      Ask FixBot
    8. Epson Stylus NX305 Scanner Motor Replacement: step 8, image 1 of 1
      • Remove the two 3mm Phillips #2 screws from the scanner motor assembly.
      • Carefully lift the scanner motor assembly out of the housing making sure not to damage the wiring.
      Ask FixBot
    9. Epson Stylus NX305 Scanner Motor Replacement: step 9, image 1 of 1
      • Flip over the scanner motor assembly to expose the scanner motor.
      • Remove the two 3mm Phillips #2 screws from the assembly and remove the motor.
      Ask FixBot
Jeffrey Barnett
101 Reputation
1 Guide authored
USF Tampa, Team 1-2, Donnelly Fall 2014 Member of USF Tampa, Team 1-2, Donnelly Fall 2014
USFT-DONNELLY-F14S1G2
1 Member
12 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 11
Past 30 Days: 29
All Time: 802
