Epson Stylus NX240 Side Buttons Replacement
    1. Epson Stylus NX240 Side Buttons Replacement, Side Buttons: step 1, image 1 of 2 Epson Stylus NX240 Side Buttons Replacement, Side Buttons: step 1, image 2 of 2
      • Go to the left side of the printer and locate the control panel with the buttons on it.
      • Take a plastic opening tool and stick it in the crack between the top of the panel and the body of the printer.
      • Pry the cover of the panel away from the body of the printer until the panel releases from the body of the printer.
      Ask FixBot
    2. Epson Stylus NX240 Side Buttons Replacement: step 2, image 1 of 1
      • Carefully lift up the panel cover and turn it to its side so that the buttons are facing towards the rest of the printer.
      • Notice that the panel cover is attached to the printer with a ribbon cable. The ribbon cable must stay connected to the body of the printer or else the buttons will be unresponsive once replaced.
      Ask FixBot
    3. Epson Stylus NX240 Side Buttons Replacement: step 3, image 1 of 1
      • Remove the six 3mm Phillips #2 screws connecting the control panel to the circuit board.
      Ask FixBot
    4. Epson Stylus NX240 Side Buttons Replacement: step 4, image 1 of 1
      • After unscrewing, carefully lift the plastic part of the control panel away from the circuit board.
      • The plastic part of the control panel is now separate.
      Ask FixBot
    5. Epson Stylus NX240 Side Buttons Replacement: step 5, image 1 of 1
      • Flip over the plastic part of the now separated control panel.
      • Remove the buttons by pulling them up with your fingers.
      Ask FixBot
    6. Epson Stylus NX240 Side Buttons Replacement: step 6, image 1 of 1
      • All parts should be separate now to clean or replace.
      Ask FixBot
Joshua Fabel
104 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 7
Past 7 Days: 20
Past 30 Days: 34
All Time: 1,021
