Epson Powerlite S4 Front Adjustable Foot Replacement
    1. Epson Powerlite S4 Front Adjustable Foot Replacement, Motherboard: step 1, image 1 of 1
      • Press the power button located on top of the projector.
      • Remember to let the projector cool off completely after turning off the power before beginning the repair.
      Ask FixBot
    2. Epson Powerlite S4 Front Adjustable Foot Replacement: step 2, image 1 of 2 Epson Powerlite S4 Front Adjustable Foot Replacement: step 2, image 2 of 2
      • Using the Phillips #1 screwdriver, loosen the single captive screw on the right side of the projector.
      • The captive screw will loosen, but it cannot be fully removed.
      • Slide the panel off and remove it from the device.
      Ask FixBot
    3. Epson Powerlite S4 Front Adjustable Foot Replacement: step 3, image 1 of 2 Epson Powerlite S4 Front Adjustable Foot Replacement: step 3, image 2 of 2
      • Remove seven black 10 mm screws from the bottom of the device using a Phillips #1 screwdriver.
      • You may need to use a screwdriver extender to reach the seven screws.
      • Remove three smaller silver screws using a Phillips #1 screwdriver.
      Ask FixBot
    4. Epson Powerlite S4 Front Adjustable Foot Replacement: step 4, image 1 of 3 Epson Powerlite S4 Front Adjustable Foot Replacement: step 4, image 2 of 3 Epson Powerlite S4 Front Adjustable Foot Replacement: step 4, image 3 of 3
      • Turn the projector so the power button is on top.
      • Gently pull up the cover until it pops off.
      • Do not pull too far; a ribbon cable still connects the top cover to the motherboard.
      • Disconnect the ribbon cable that attaches the cover to the motherboard.
      • Remove the cover and place to the side.
      Ask FixBot
    5. Epson Powerlite S4 Front Adjustable Foot Replacement: step 5, image 1 of 1
      • Remove the three screws holding down the motherboard using a Phillips #1 screwdriver.
      Ask FixBot
    6. Epson Powerlite S4 Front Adjustable Foot Replacement: step 6, image 1 of 1
      • Ensure that the two large cable cords located in the center are disconnected.
      Ask FixBot
    7. Epson Powerlite S4 Front Adjustable Foot Replacement: step 7, image 1 of 1
      • Remove the nine cables that are running to the motherboard by pulling them up out of their sockets.
      • You may need a spudger or a plastic opening tool to disconnect all of the wires connected to the motherboard.
      Ask FixBot
    8. Epson Powerlite S4 Front Adjustable Foot Replacement: step 8, image 1 of 1
      • Carefully lift the motherboard from the edges.
      • Remove from base and set aside.
      Ask FixBot
    1. Epson Powerlite S4 Front Adjustable Foot Replacement, Front Adjustable Foot: step 9, image 1 of 2 Epson Powerlite S4 Front Adjustable Foot Replacement, Front Adjustable Foot: step 9, image 2 of 2
      • To the left of the lens, you'll find the adjustable foot.
      • Remove the screw to the left of the adjustable foot using a Phillips #0 screwdriver.
      • Lift up the adjustable foot to remove it from the projector.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 9
Past 30 Days: 31
All Time: 473
