Epson Powerlite 460 Power Supply Replacement
  1. Epson Powerlite 460 Power Supply Replacement, Power Supply: step 1, image 1 of 3 Epson Powerlite 460 Power Supply Replacement, Power Supply: step 1, image 2 of 3 Epson Powerlite 460 Power Supply Replacement, Power Supply: step 1, image 3 of 3
    • Remove the eleven 13.3mm screws using a Phillips #2 screwdriver.
    • Remove the bottom cover of the projector.
    • Flip the device over and remove the air filter cover.
    Ask FixBot
  2. Epson Powerlite 460 Power Supply Replacement: step 2, image 1 of 3 Epson Powerlite 460 Power Supply Replacement: step 2, image 2 of 3 Epson Powerlite 460 Power Supply Replacement: step 2, image 3 of 3
    • Remove the two 13.3 mm screws from the top cover by the air filter cover.
    • Remove the one 13.3 mm screw above the connection panel.
    • Remove the top cover and lay to the side connected to the power supply.
    • The cover will be connected by ribbon cables. You do not need to disconnect these to complete this repair, but it may make it easier.
    Ask FixBot
  3. Epson Powerlite 460 Power Supply Replacement: step 3, image 1 of 3 Epson Powerlite 460 Power Supply Replacement: step 3, image 2 of 3 Epson Powerlite 460 Power Supply Replacement: step 3, image 3 of 3
    • Using the Phillips #2 screwdriver, remove the six 13.3 mm screws on the ABS black cover and AC power inlet above the power supply.
    • Lift up cover and inlet and set to the side.
    Ask FixBot
  4. Epson Powerlite 460 Power Supply Replacement: step 4, image 1 of 2 Epson Powerlite 460 Power Supply Replacement: step 4, image 2 of 2
    • Using the Phillips #2 screwdriver, remove the 7.7 mm screw attached to the ring terminal.
    Ask FixBot
  5. Epson Powerlite 460 Power Supply Replacement: step 5, image 1 of 1
    • Using the opening tool, unclip the white clip cable by pressing the side tabs.
    Ask FixBot
  6. Epson Powerlite 460 Power Supply Replacement: step 6, image 1 of 2 Epson Powerlite 460 Power Supply Replacement: step 6, image 2 of 2
    • Using the opening tool or a spudger, unclip the power supply from the base.
    • Remove the power supply.
    Ask FixBot
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 3
Past 30 Days: 16
All Time: 303
