Up to 20% off select tools
Epson Powerlite 460 Filter Replacement
View statistics:
Past 24 Hours:
3
Past 7 Days:
15
Past 30 Days:
54
All Time:
575
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 4 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
This guide demonstrates how to remove and replace the air filter in your Epson PowerLite 460.
A filter keeps the dust and debris out of the device in order for the device to stay clean. Overheating can occur if the air filter is damaged or clogged, which can cause the device to not run properly. If so, replace or clean the filter.
Review the troubleshooting guide before replacing the filter. Other factors can cause overheating in the Powerlite 460.
    1. Epson Powerlite 460 Filter Replacement, Filter: step 1, image 1 of 1
      • Orient the device with the projection window on top with the name of the device right side up.
      Ask FixBot
    2. Epson Powerlite 460 Filter Replacement: step 2, image 1 of 1
      • Slide the air filter cover opener in the direction indicated by the arrow to release the air filter cover.
      Ask FixBot
    3. Epson Powerlite 460 Filter Replacement: step 3, image 1 of 2 Epson Powerlite 460 Filter Replacement: step 3, image 2 of 2
      • Open the air filter cover by pulling the top down and away from the device.
      Ask FixBot
    4. Epson Powerlite 460 Filter Replacement: step 4, image 1 of 2 Epson Powerlite 460 Filter Replacement: step 4, image 2 of 2
      • Pinch the air filter cover handle and gently pull the filter away from the device
      • This may take a small amount of force.
      Ask FixBot
Author
with
Korinna Curry
268 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 15
Past 30 Days: 54
All Time: 575
