Epson Powerlite 410W Motherboard Replacement
  1. Epson Powerlite 410W Motherboard Replacement, Top Cover: step 1, image 1 of 1
    • Press the power button located on top of the projector.
    • Remember to let the projector cool off completely after turning off the power before beginning the repair.
    Ask FixBot
  2. Epson Powerlite 410W Motherboard Replacement: step 2, image 1 of 1
    • Remove eight screws from the bottom of the device using a Phillips #00 screwdriver.
    Ask FixBot
  3. Epson Powerlite 410W Motherboard Replacement: step 3, image 1 of 3 Epson Powerlite 410W Motherboard Replacement: step 3, image 2 of 3 Epson Powerlite 410W Motherboard Replacement: step 3, image 3 of 3
    • Turn the projector so the power button is on top.
    • Gently pull up the cover until it pops off.
    • Do not pull too far; a ribbon cable still connects the top cover to the motherboard.
    • Disconnect the ribbon cable that attaches the cover to the motherboard.
    • Remove the cover and place to the side.
    Ask FixBot
  4. Epson Powerlite 410W Motherboard Replacement, Motherboard: step 4, image 1 of 2 Epson Powerlite 410W Motherboard Replacement, Motherboard: step 4, image 2 of 2
    • Remove the two screws holding down the motherboard using a Phillips #00 screwdriver.
    • Remove the four screws holding down the I/O board using a Phillips #00 screwdriver.
    Ask FixBot
  5. Epson Powerlite 410W Motherboard Replacement: step 5, image 1 of 1
    • Remove the seven cables that are running to the motherboard by pulling them out of their sockets.
    Ask FixBot
  6. Epson Powerlite 410W Motherboard Replacement: step 6, image 1 of 3 Epson Powerlite 410W Motherboard Replacement: step 6, image 2 of 3 Epson Powerlite 410W Motherboard Replacement: step 6, image 3 of 3
    Tool used on this step:
    Buy
    • Using a plastic opening tool, gently pry up the black tabs holding in the ribbon cables on the motherboard.
    • Using tweezers, gently pull the ribbon cables out of the sockets.
    Ask FixBot
  7. Epson Powerlite 410W Motherboard Replacement: step 7, image 1 of 1
    • Gently pull the motherboard up and tilt it back, revealing the last cable attached to the motherboard. Disconnect this cable.
    • Remove the motherboard from the projector.
    Ask FixBot
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 26
All Time: 350
