Epson PowerLite 83+ Speaker Replacement
    1. Epson PowerLite 83+ Speaker Replacement, Motherboard: step 1, image 1 of 3 Epson PowerLite 83+ Speaker Replacement, Motherboard: step 1, image 2 of 3 Epson PowerLite 83+ Speaker Replacement, Motherboard: step 1, image 3 of 3
      • Remove the eight 5mm Phillips #2 screws securing the projector's bottom cover.
      • A long shank Phillips #2 screwdriver is required to reach the screws.
      Ask FixBot
    2. Epson PowerLite 83+ Speaker Replacement: step 2, image 1 of 3 Epson PowerLite 83+ Speaker Replacement: step 2, image 2 of 3 Epson PowerLite 83+ Speaker Replacement: step 2, image 3 of 3
      • Flip the projector over and lift the top cover from the rear of the projector.
      • Two cables are connected at the front that prevent full removal.
      • Disconnect the slide cover JST connector. Grip the connector and rock it back and forth while apply gentle pressure.
      Ask FixBot
    3. Epson PowerLite 83+ Speaker Replacement: step 3, image 1 of 2 Epson PowerLite 83+ Speaker Replacement: step 3, image 2 of 2
      • Using a spudger, lift the ribbon cable's locking tab along the length of the cable.
      • Remove the ribbon cable from the connector and place the projector's top cover aside.
      Ask FixBot
    4. Epson PowerLite 83+ Speaker Replacement: step 4, image 1 of 3 Epson PowerLite 83+ Speaker Replacement: step 4, image 2 of 3 Epson PowerLite 83+ Speaker Replacement: step 4, image 3 of 3
      • Remove the two 6 mm Phillips #2 screws.
      • Remove the single silver 5 mm Phillips #2 screw.
      Ask FixBot
    5. Epson PowerLite 83+ Speaker Replacement: step 5, image 1 of 3 Epson PowerLite 83+ Speaker Replacement: step 5, image 2 of 3 Epson PowerLite 83+ Speaker Replacement: step 5, image 3 of 3
      • Using your fingernails or a spudger, remove the eleven JST connectors attached to the motherboard.
      Ask FixBot
    6. Epson PowerLite 83+ Speaker Replacement: step 6, image 1 of 2 Epson PowerLite 83+ Speaker Replacement: step 6, image 2 of 2
      • Using a spudger, flip up the plastic locking tabs and gently remove the three ribbon cables from their connectors.
      Ask FixBot
    7. Epson PowerLite 83+ Speaker Replacement: step 7, image 1 of 2 Epson PowerLite 83+ Speaker Replacement: step 7, image 2 of 2
      • Ensure all JST connectors are clear of the motherboard and that the ribbon cables freely move in their motherboard cutouts.
      • Lift the motherboard from the front side of the projector to clear the ribbon cables.
      • Disconnect the speaker's JST connector on the underside of the motherboard using your fingernails.
      • Remove the motherboard from the case.
      Ask FixBot
    1. Epson PowerLite 83+ Speaker Replacement, Exhaust Fan: step 8, image 1 of 2 Epson PowerLite 83+ Speaker Replacement, Exhaust Fan: step 8, image 2 of 2
      • Loosen the two captive Phillips #2 screws securing the lamp.
      • Captive screws should not be removed. They are secured to the lamp itself with retaining rings and will be removed along with the lamp.
      Ask FixBot
    2. Epson PowerLite 83+ Speaker Replacement: step 9, image 1 of 1
      • Hold onto the indented areas of the lamp with your fingers and gently pull it upwards to remove it from the casing.
      Ask FixBot
    3. Epson PowerLite 83+ Speaker Replacement: step 10, image 1 of 3 Epson PowerLite 83+ Speaker Replacement: step 10, image 2 of 3 Epson PowerLite 83+ Speaker Replacement: step 10, image 3 of 3
      • Remove the four 6 mm Phillips #2 screws.
      • Lift the fan bracket straight up to remove it from the casing.
      Ask FixBot
    4. Epson PowerLite 83+ Speaker Replacement: step 11, image 1 of 2 Epson PowerLite 83+ Speaker Replacement: step 11, image 2 of 2
      • A long, thin shank Phillips #2 screwdriver is required to remove the screws.
      Ask FixBot
    5. Epson PowerLite 83+ Speaker Replacement: step 12, image 1 of 2 Epson PowerLite 83+ Speaker Replacement: step 12, image 2 of 2
      • Remove the exhaust fan from the bracket.
      Ask FixBot
    1. Epson PowerLite 83+ Speaker Replacement, Projector Lens: step 13, image 1 of 3 Epson PowerLite 83+ Speaker Replacement, Projector Lens: step 13, image 2 of 3 Epson PowerLite 83+ Speaker Replacement, Projector Lens: step 13, image 3 of 3
      • Remove the four 6 mm Phillips #2 screws securing the fan bracket.
      • Remove the fan bracket by pulling straight up and set it aside.
      Ask FixBot
    2. Epson PowerLite 83+ Speaker Replacement: step 14, image 1 of 3 Epson PowerLite 83+ Speaker Replacement: step 14, image 2 of 3 Epson PowerLite 83+ Speaker Replacement: step 14, image 3 of 3
      • Remove the four 6 mm Phillips #2 screws securing the projector lens.
      Ask FixBot
    3. Epson PowerLite 83+ Speaker Replacement: step 15, image 1 of 2 Epson PowerLite 83+ Speaker Replacement: step 15, image 2 of 2
      • Unhook the JST connector wire from wire stay and move it aside.
      • Remove the projector lens from the base.
      Ask FixBot
    1. Epson PowerLite 83+ Speaker Replacement, Speaker: step 16, image 1 of 2 Epson PowerLite 83+ Speaker Replacement, Speaker: step 16, image 2 of 2
      • Remove the three 6 mm Phillips #2 screws.
      Ask FixBot
    2. Epson PowerLite 83+ Speaker Replacement: step 17, image 1 of 1
      • Remove the speaker from the projector case.
      Ask FixBot
Lucas Bell
229 Reputation
2 Guides authored
Clemson, Team 2-4, Hunter Spring 2022 Member of Clemson, Team 2-4, Hunter Spring 2022
CLEM-HUNTER-S22S2G4
4 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 21
All Time: 294
