Up to 20% off select tools
Epson PowerLite 83+ Projector Lens Replacement
Views: 1.2K
View statistics:
Past 24 Hours:
Past 7 Days:
14
Past 30 Days:
72
All Time:
1,193
Comments: 1
1 guide comment.
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 20 - 50 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
If the image is blurred, out of focus or distorted, and the cause is not in the menu settings or lens smudges, the projector lens may need to be replaced. Prior to replacement, refer to the Troubleshooting page for additional solutions. Follow this guide to replace the projector lens of your Epson PowerLite 83+ projector.
Before beginning this repair, make sure the the projector is off and unplugged from the power adapter.
    1. Epson PowerLite 83+ Projector Lens Replacement, Motherboard: step 1, image 1 of 3 Epson PowerLite 83+ Projector Lens Replacement, Motherboard: step 1, image 2 of 3 Epson PowerLite 83+ Projector Lens Replacement, Motherboard: step 1, image 3 of 3
      • Remove the eight 5mm Phillips #2 screws securing the projector's bottom cover.
      • A long shank Phillips #2 screwdriver is required to reach the screws.
      Ask FixBot
    2. Epson PowerLite 83+ Projector Lens Replacement: step 2, image 1 of 3 Epson PowerLite 83+ Projector Lens Replacement: step 2, image 2 of 3 Epson PowerLite 83+ Projector Lens Replacement: step 2, image 3 of 3
      • Flip the projector over and lift the top cover from the rear of the projector.
      • Two cables are connected at the front that prevent full removal.
      • Disconnect the slide cover JST connector. Grip the connector and rock it back and forth while apply gentle pressure.
      Ask FixBot
    3. Epson PowerLite 83+ Projector Lens Replacement: step 3, image 1 of 2 Epson PowerLite 83+ Projector Lens Replacement: step 3, image 2 of 2
      • Using a spudger, lift the ribbon cable's locking tab along the length of the cable.
      • Remove the ribbon cable from the connector and place the projector's top cover aside.
      Ask FixBot
    4. Epson PowerLite 83+ Projector Lens Replacement: step 4, image 1 of 3 Epson PowerLite 83+ Projector Lens Replacement: step 4, image 2 of 3 Epson PowerLite 83+ Projector Lens Replacement: step 4, image 3 of 3
      • Remove the two 6 mm Phillips #2 screws.
      • Remove the single silver 5 mm Phillips #2 screw.
      Ask FixBot
    5. Epson PowerLite 83+ Projector Lens Replacement: step 5, image 1 of 3 Epson PowerLite 83+ Projector Lens Replacement: step 5, image 2 of 3 Epson PowerLite 83+ Projector Lens Replacement: step 5, image 3 of 3
      • Using your fingernails or a spudger, remove the eleven JST connectors attached to the motherboard.
      Ask FixBot
    6. Epson PowerLite 83+ Projector Lens Replacement: step 6, image 1 of 2 Epson PowerLite 83+ Projector Lens Replacement: step 6, image 2 of 2
      • Using a spudger, flip up the plastic locking tabs and gently remove the three ribbon cables from their connectors.
      Ask FixBot
    7. Epson PowerLite 83+ Projector Lens Replacement: step 7, image 1 of 2 Epson PowerLite 83+ Projector Lens Replacement: step 7, image 2 of 2
      • Ensure all JST connectors are clear of the motherboard and that the ribbon cables freely move in their motherboard cutouts.
      • Lift the motherboard from the front side of the projector to clear the ribbon cables.
      • Disconnect the speaker's JST connector on the underside of the motherboard using your fingernails.
      • Remove the motherboard from the case.
      Ask FixBot
    1. Epson PowerLite 83+ Projector Lens Replacement, Projector Lens: step 8, image 1 of 3 Epson PowerLite 83+ Projector Lens Replacement, Projector Lens: step 8, image 2 of 3 Epson PowerLite 83+ Projector Lens Replacement, Projector Lens: step 8, image 3 of 3
      • Remove the four 6 mm Phillips #2 screws securing the fan bracket.
      • Remove the fan bracket by pulling straight up and set it aside.
      Ask FixBot
    2. Epson PowerLite 83+ Projector Lens Replacement: step 9, image 1 of 3 Epson PowerLite 83+ Projector Lens Replacement: step 9, image 2 of 3 Epson PowerLite 83+ Projector Lens Replacement: step 9, image 3 of 3
      • Remove the four 6 mm Phillips #2 screws securing the projector lens.
      Ask FixBot
    3. Epson PowerLite 83+ Projector Lens Replacement: step 10, image 1 of 2 Epson PowerLite 83+ Projector Lens Replacement: step 10, image 2 of 2
      • Unhook the JST connector wire from wire stay and move it aside.
      • Remove the projector lens from the base.
      Ask FixBot
Author
with
Billy Fox
467 Reputation
3 Guides authored
Clemson, Team 2-4, Hunter Spring 2022 Member of Clemson, Team 2-4, Hunter Spring 2022
CLEM-HUNTER-S22S2G4
4 Members
72 Guides authored
1 Guide Comment
source for a replacement lens? I surely need one.
christopher wanko - Reply Share
Past 24 Hours: 1
Past 7 Days: 14
Past 30 Days: 72
All Time: 1,193
