Up to 20% off select tools
Epson PowerLite 83+ Fan Replacement
View statistics:
Past 24 Hours:
Past 7 Days:
13
Past 30 Days:
65
All Time:
769
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 30 minutes - 1 hour
Difficulty: Moderate
Parts
Tools
Introduction
Go to step 1 ↓
Use this guide to access and replace the fan of your Epson PowerLite 83+ projector.
In the case of overheating, the fan may be in need of dusting or replacement. If the device is overheating and the filter has been cleaned or replaced, the issue may be caused by the exhaust fan.
This is not a highly difficult fix, but it does require the removal of the main cover and the lamp. Be sure to turn the device off and unplug it from the power adapter prior to beginning this repair.
    1. Epson PowerLite 83+ Fan Replacement, Motherboard: step 1, image 1 of 3 Epson PowerLite 83+ Fan Replacement, Motherboard: step 1, image 2 of 3 Epson PowerLite 83+ Fan Replacement, Motherboard: step 1, image 3 of 3
      • Remove the eight 5mm Phillips #2 screws securing the projector's bottom cover.
      • A long shank Phillips #2 screwdriver is required to reach the screws.
      Ask FixBot
    2. Epson PowerLite 83+ Fan Replacement: step 2, image 1 of 3 Epson PowerLite 83+ Fan Replacement: step 2, image 2 of 3 Epson PowerLite 83+ Fan Replacement: step 2, image 3 of 3
      • Flip the projector over and lift the top cover from the rear of the projector.
      • Two cables are connected at the front that prevent full removal.
      • Disconnect the slide cover JST connector. Grip the connector and rock it back and forth while apply gentle pressure.
      Ask FixBot
    3. Epson PowerLite 83+ Fan Replacement: step 3, image 1 of 2 Epson PowerLite 83+ Fan Replacement: step 3, image 2 of 2
      • Using a spudger, lift the ribbon cable's locking tab along the length of the cable.
      • Remove the ribbon cable from the connector and place the projector's top cover aside.
      Ask FixBot
    4. Epson PowerLite 83+ Fan Replacement: step 4, image 1 of 3 Epson PowerLite 83+ Fan Replacement: step 4, image 2 of 3 Epson PowerLite 83+ Fan Replacement: step 4, image 3 of 3
      • Remove the two 6 mm Phillips #2 screws.
      • Remove the single silver 5 mm Phillips #2 screw.
      Ask FixBot
    5. Epson PowerLite 83+ Fan Replacement: step 5, image 1 of 3 Epson PowerLite 83+ Fan Replacement: step 5, image 2 of 3 Epson PowerLite 83+ Fan Replacement: step 5, image 3 of 3
      • Using your fingernails or a spudger, remove the eleven JST connectors attached to the motherboard.
      Ask FixBot
    6. Epson PowerLite 83+ Fan Replacement: step 6, image 1 of 2 Epson PowerLite 83+ Fan Replacement: step 6, image 2 of 2
      • Using a spudger, flip up the plastic locking tabs and gently remove the three ribbon cables from their connectors.
      Ask FixBot
    7. Epson PowerLite 83+ Fan Replacement: step 7, image 1 of 2 Epson PowerLite 83+ Fan Replacement: step 7, image 2 of 2
      • Ensure all JST connectors are clear of the motherboard and that the ribbon cables freely move in their motherboard cutouts.
      • Lift the motherboard from the front side of the projector to clear the ribbon cables.
      • Disconnect the speaker's JST connector on the underside of the motherboard using your fingernails.
      • Remove the motherboard from the case.
      Ask FixBot
    1. Epson PowerLite 83+ Fan Replacement, Exhaust Fan: step 8, image 1 of 2 Epson PowerLite 83+ Fan Replacement, Exhaust Fan: step 8, image 2 of 2
      • Loosen the two captive Phillips #2 screws securing the lamp.
      • Captive screws should not be removed. They are secured to the lamp itself with retaining rings and will be removed along with the lamp.
      Ask FixBot
    2. Epson PowerLite 83+ Fan Replacement: step 9, image 1 of 1
      • Hold onto the indented areas of the lamp with your fingers and gently pull it upwards to remove it from the casing.
      Ask FixBot
    3. Epson PowerLite 83+ Fan Replacement: step 10, image 1 of 3 Epson PowerLite 83+ Fan Replacement: step 10, image 2 of 3 Epson PowerLite 83+ Fan Replacement: step 10, image 3 of 3
      • Remove the four 6 mm Phillips #2 screws.
      • Lift the fan bracket straight up to remove it from the casing.
      Ask FixBot
    4. Epson PowerLite 83+ Fan Replacement: step 11, image 1 of 2 Epson PowerLite 83+ Fan Replacement: step 11, image 2 of 2
      • A long, thin shank Phillips #2 screwdriver is required to remove the screws.
      Ask FixBot
    5. Epson PowerLite 83+ Fan Replacement: step 12, image 1 of 2 Epson PowerLite 83+ Fan Replacement: step 12, image 2 of 2
      • Remove the exhaust fan from the bracket.
      Ask FixBot
Author
with
Billy Fox
467 Reputation
3 Guides authored
Clemson, Team 2-4, Hunter Spring 2022 Member of Clemson, Team 2-4, Hunter Spring 2022
CLEM-HUNTER-S22S2G4
4 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 13
Past 30 Days: 65
All Time: 769
