Epson PowerLite 822 Plus Projector Lens Replacement
    1. Epson PowerLite 822 Plus Projector Lens Replacement, Motherboard: step 1, image 1 of 1
      • Flip the projector over.
      • Remove all 8 screws on the bottom of the projector.
      Ask FixBot
    2. Epson PowerLite 822 Plus Projector Lens Replacement: step 2, image 1 of 2 Epson PowerLite 822 Plus Projector Lens Replacement: step 2, image 2 of 2
      • Now, flip the projector back over and pry the top of it open revealing the inside of the projector.
      Ask FixBot
    3. Epson PowerLite 822 Plus Projector Lens Replacement: step 3, image 1 of 2 Epson PowerLite 822 Plus Projector Lens Replacement: step 3, image 2 of 2
      • Use the spudger to disconnect it from the motherboard.
      Ask FixBot
    4. Epson PowerLite 822 Plus Projector Lens Replacement: step 4, image 1 of 2 Epson PowerLite 822 Plus Projector Lens Replacement: step 4, image 2 of 2
      • Using your finger gently move back and forth the JST cable that connects the top to the motherboard.
      • Now completely take off the top of the projector.
      Ask FixBot
    5. Epson PowerLite 822 Plus Projector Lens Replacement: step 5, image 1 of 2 Epson PowerLite 822 Plus Projector Lens Replacement: step 5, image 2 of 2
      • Remove the 3 screws that secure the motherboard in place.
      Ask FixBot
    6. Epson PowerLite 822 Plus Projector Lens Replacement: step 6, image 1 of 3 Epson PowerLite 822 Plus Projector Lens Replacement: step 6, image 2 of 3 Epson PowerLite 822 Plus Projector Lens Replacement: step 6, image 3 of 3
      • Gently move back and forth the 11 JST connectors until they come out.
      Ask FixBot
    7. Epson PowerLite 822 Plus Projector Lens Replacement: step 7, image 1 of 2 Epson PowerLite 822 Plus Projector Lens Replacement: step 7, image 2 of 2
      • With the spudger lift the red plastic tabs from their connectors.
      Ask FixBot
    8. Epson PowerLite 822 Plus Projector Lens Replacement: step 8, image 1 of 3 Epson PowerLite 822 Plus Projector Lens Replacement: step 8, image 2 of 3 Epson PowerLite 822 Plus Projector Lens Replacement: step 8, image 3 of 3
      • Lift the motherboard and disconnect the JST connector underneath.
      Ask FixBot
    9. Epson PowerLite 822 Plus Projector Lens Replacement: step 9, image 1 of 1
      • Now, the motherboard is completely removed from the projector and you are ready to replace it.
      Ask FixBot
    1. Epson PowerLite 822 Plus Projector Lens Replacement, Projector Lens: step 10, image 1 of 3 Epson PowerLite 822 Plus Projector Lens Replacement, Projector Lens: step 10, image 2 of 3 Epson PowerLite 822 Plus Projector Lens Replacement, Projector Lens: step 10, image 3 of 3
      • Use a Phillips #2 screwdriver to remove the four 6 mm screws that hold together the fan bracket.
      Ask FixBot
    2. Epson PowerLite 822 Plus Projector Lens Replacement: step 11, image 1 of 2 Epson PowerLite 822 Plus Projector Lens Replacement: step 11, image 2 of 2
      • Use a Phillips #2 screwdriver to remove the four 6 mm screws that secure the projector.
      Ask FixBot
    3. Epson PowerLite 822 Plus Projector Lens Replacement: step 12, image 1 of 2 Epson PowerLite 822 Plus Projector Lens Replacement: step 12, image 2 of 2
      • Pull out the loose projector and it is ready to be replaced.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 6
Past 30 Days: 26
All Time: 292
