Epson PowerLite 822 Plus Lamp Replacement
    1. Epson PowerLite 822 Plus Lamp Replacement, Lamp: step 1, image 1 of 1
      • If you just used the projector you will want to let it sit for about an hour to cool off.
      • If you have not used the projector within the past few hours you are ready to get to work.
      Ask FixBot
    2. Epson PowerLite 822 Plus Lamp Replacement: step 2, image 1 of 2 Epson PowerLite 822 Plus Lamp Replacement: step 2, image 2 of 2
      • Use a Phillips #2 screwdriver to remove the 6 mm screw that holds the lamp cover in place.
      Ask FixBot
    3. Epson PowerLite 822 Plus Lamp Replacement: step 3, image 1 of 3 Epson PowerLite 822 Plus Lamp Replacement: step 3, image 2 of 3 Epson PowerLite 822 Plus Lamp Replacement: step 3, image 3 of 3
      • Apply pressure to the lamp cover, pulling it towards the end of the projector.
      • Pop the lamp cover off, exposing the lamp.
      Ask FixBot
    4. Epson PowerLite 822 Plus Lamp Replacement: step 4, image 1 of 3 Epson PowerLite 822 Plus Lamp Replacement: step 4, image 2 of 3 Epson PowerLite 822 Plus Lamp Replacement: step 4, image 3 of 3
      • There are two 9mm screws which have already been loosened. These screws do not come all the way out.
      • Grip the finger hold and pull it straight out of the projector.
      Ask FixBot
    5. Epson PowerLite 822 Plus Lamp Replacement: step 5, image 1 of 1
      • After pulling it straight up by the finger hold the lamp will be revealed and ready to be replaced.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 4
Past 30 Days: 20
All Time: 375
