Epson PictureMate Pal PM 200 Display Replacement
  1. Epson PictureMate Pal PM 200 Display Replacement, Printer Top Plate: step 1, image 1 of 3 Epson PictureMate Pal PM 200 Display Replacement, Printer Top Plate: step 1, image 2 of 3 Epson PictureMate Pal PM 200 Display Replacement, Printer Top Plate: step 1, image 3 of 3
    • Be certain that device is powered off and unplugged as to not damage any of the internal components before beginning.
    • Power off device and use a metal spudger to remove each of the two caps over the screws that hold the top plate to the device.
    Ask FixBot
  2. Epson PictureMate Pal PM 200 Display Replacement: step 2, image 1 of 1
    • Remove the two 6 mm Phillips screws.
    Ask FixBot
  3. Epson PictureMate Pal PM 200 Display Replacement: step 3, image 1 of 2 Epson PictureMate Pal PM 200 Display Replacement: step 3, image 2 of 2
    • Gently lift the lid and turn it to face the daughterboard underneath.
    • Gently pull the no-fuss ribbon cable out from its connector.
    • The other end of the ribbon cable is still in the device's motherboard. Only remove the end connected to the daughterboard unless stated in a later step in order to not lose it due to unnecessary removal.
    Ask FixBot
  4. Epson PictureMate Pal PM 200 Display Replacement: step 4, image 1 of 2 Epson PictureMate Pal PM 200 Display Replacement: step 4, image 2 of 2
    • Remove the printer top plate.
    Ask FixBot
  5. Epson PictureMate Pal PM 200 Display Replacement, Display: step 5, image 1 of 1
    • Set the panel to the side on a neat, flat surface.
    Ask FixBot
  6. Epson PictureMate Pal PM 200 Display Replacement: step 6, image 1 of 3 Epson PictureMate Pal PM 200 Display Replacement: step 6, image 2 of 3 Epson PictureMate Pal PM 200 Display Replacement: step 6, image 3 of 3
    • Remove the two 8 mm Phillips screws securing the display assembly to the top panel.
    Ask FixBot
  7. Epson PictureMate Pal PM 200 Display Replacement: step 7, image 1 of 2 Epson PictureMate Pal PM 200 Display Replacement: step 7, image 2 of 2
    • Pull the black ZIF locking flap toward the ribbon cable.
    • Disconnect the ribbon cable from the daughterboard.
    Ask FixBot
  8. Epson PictureMate Pal PM 200 Display Replacement: step 8, image 1 of 2 Epson PictureMate Pal PM 200 Display Replacement: step 8, image 2 of 2
    • Remove the display assembly from the top panel.
    Ask FixBot
  9. Epson PictureMate Pal PM 200 Display Replacement: step 9, image 1 of 2 Epson PictureMate Pal PM 200 Display Replacement: step 9, image 2 of 2
    • Remove the two 8 mm screws that secure the display to the housing.
    Ask FixBot
  10. Epson PictureMate Pal PM 200 Display Replacement: step 10, image 1 of 3 Epson PictureMate Pal PM 200 Display Replacement: step 10, image 2 of 3 Epson PictureMate Pal PM 200 Display Replacement: step 10, image 3 of 3
    • Remove the display from the housing.
    Ask FixBot
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
Andre
484 Reputation
4 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 18
All Time: 159
