Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Needs More Images
A few more images would make this guide's procedures crystal clear.
Tools
Spudger4.9
Introduction
Go to step 1 ↓If your Epson PPC650’s screen is cracked, unresponsive, or displaying distorted images, this guide will walk you through replacing the screen to restore full functionality.
Before beginning, check for any loose connections or software issues that might be causing display problems. If the screen remains unresponsive or physically damaged, replacement is necessary.
This repair requires careful handling of delicate components. If the screen is shattered, use protective gloves to avoid injury. Additionally, be sure to power off the device and disconnect it from any external power sources before starting the repair.
Locate the silver power button. Gently slide the button to the middle section labeled "off" to shut down the camera.
Remove the batteries from the battery compartment located on the underside of the camera.
Remove the SD card from the compartment located on the flat, left side of the camera.
Remove the copper sheet from the front and back paneling.
Use the spudger to unsolder the copper paneling.
Use the spudger to separate the back circuit board from the camera.
