Up to 20% off select tools
Epson PPC650 Camera Case Replacement
View statistics:
Past 24 Hours:
5
Past 7 Days:
26
Past 30 Days:
109
All Time:
933
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: No estimate
Difficulty: Moderate
Missing Details
Some of this guide's details are missing. Help users by adding tools, difficulty, or time.
Tools
  • Spudger
    4.9
  • 64 Bit Driver Kit
    $33.96 $39.95
    4.9
    1. Epson PPC650 Camera Case Replacement, Case: step 1, image 1 of 3 Epson PPC650 Camera Case Replacement, Case: step 1, image 2 of 3 Epson PPC650 Camera Case Replacement, Case: step 1, image 3 of 3
      • Locate the silver power button. Gently slide the button to the middle section labeled "off" to shut down the camera.
      • Remove the batteries from the battery compartment located on the underside of the camera.
      • Remove the SD card from the compartment located on the flat, left side of the camera.
      Ask FixBot
    2. Epson PPC650 Camera Case Replacement: step 2, image 1 of 1
      • Remove the two screws on the rounded side of the camera.
      Ask FixBot
    3. Epson PPC650 Camera Case Replacement: step 3, image 1 of 2 Epson PPC650 Camera Case Replacement: step 3, image 2 of 2
      • Remove the three screws on the flat side of the camera.
      • All of the silver screws go into the side of the camera that is silver.
      • All of the black screws go into the side of the camera that is black.
      Ask FixBot
    4. Epson PPC650 Camera Case Replacement: step 4, image 1 of 1
      • Remove the four screws from the bottom of the camera.
      Ask FixBot
    5. Epson PPC650 Camera Case Replacement: step 5, image 1 of 3 Epson PPC650 Camera Case Replacement: step 5, image 2 of 3 Epson PPC650 Camera Case Replacement: step 5, image 3 of 3
      • Separate the front and the back pieces of the camera's plastic casing using a spudger.
      • WARNING: When pulling the front plastic casing, be careful of the wires that are connected to the aperture control.
      • Use minimal force so that the plastic casing does not break.
      • When separating the small silver siding, the indicator for the view/off/playback may fall out.
      • The plastic viewing window located on the top of the camera may also become lose and fall out.
      Ask FixBot
Author
with
Brittany
113 Reputation
1 Guide authored
Ohio State, Team 1-5, Buehl Spring 2013 Member of Ohio State, Team 1-5, Buehl Spring 2013
OSU-BUEHL-S13S1G5
4 Members
36 Guides authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 26
Past 30 Days: 109
All Time: 933
