Up to 20% off select tools
Epson EX90 Lamp Replacement
View statistics:
Past 24 Hours:
Past 7 Days:
12
Past 30 Days:
58
All Time:
571
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 5 minutes
Difficulty: Easy
Needs More Images
A few more images would make this guide's procedures crystal clear.
Introduction
Go to step 1 ↓
Epson EX90 is a portable projector that uses a 170W UHE E-TORL lamp. The average lamp life is around 3,000 hours.
If the lamp indicator flashes red or the projected image is darker, it is recommended to replace the lamp. This guide will explain how to replace the lamp on the Epson EX90. It is recommended to replace the bulb as soon as possible due to the reason below,
WARNING While rare, a bulb could explode for the following:
  • the bulb reached the end of its lifespan
  • bulb overheated
  • Improper installation
If this happens, please turn off and then unplug the projector. Thoroughly remove glass shards and vacuum around and in the projector before replacing lamp.
    1. Epson EX90 Lamp Replacement, Lamp: step 1, image 1 of 1
      • Turn off the projector and unplug the power cable.
      • Allow the projector to cool down for at least one hour (or until the lamp is cool).
      Ask FixBot
    2. Epson EX90 Lamp Replacement: step 2, image 1 of 1
      • Loosen the screw holding the lamp cover on top of the projector.
      • Slide the cover out of the projector.
      Ask FixBot
    3. Epson EX90 Lamp Replacement: step 3, image 1 of 2 Epson EX90 Lamp Replacement: step 3, image 2 of 2
      • Loosen the two captive screws holding the lamp in place.
      • Use your hands to pull the lamp straight up and out of the projector.
      Ask FixBot
Author
with
Antonio Morais
97 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 12
Past 30 Days: 58
All Time: 571
