This translation was generated by a machine and has not been reviewed by a person yet. Speak this language? Review it.
Epson ET-3750 ADF Unit Replacement
View statistics:
Past 24 Hours:
2
Past 7 Days:
12
Past 30 Days:
117
All Time:
440
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: No estimate
Difficulty: Moderate
Needs More Images
A few more images would make this guide's procedures crystal clear.
Community-Contributed Guide
Introduction
Go to step 1 ↓
If the Automatic Document Feeder (ADF) of your Epson ET-3750 is no longer working—for example, because it no longer feeds paper or regularly causes paper jams—you can replace the entire ADF unit.
This guide shows you step by step how to open the device, disconnect the ADF unit cable, and release and replace the ADF from the hinges.
⚠️ During the entire repair, be sure to keep the printer as level as possible to prevent ink from leaking.
Parts
Tools
      • Disconnect the device from power and remove all paper trays.
      • Be careful to keep the printer level throughout the repair to prevent any ink from spilling.
      Ask FixBot
      • Loosen the screws on the top front housing.
      • Carefully pry up the clips on the front and top with a plastic tool or by hand.
      • Remove the cover and set it aside.
      Ask FixBot
      • Remove the ink compartment covers on the left side and the maintenance tank cover on the bottom rear.
      Ask FixBot
      • Release all side and bottom screws.
      • Caution: Release the screws on the bottom without tilting the printer – risk of ink leaks or clogged ventilation.
      • Carefully pry off the right and left case panels.
      Ask FixBot
      • First, remove the small hinge cover on the right side.
      • Then, release the large rear top cover to gain access to the cables.
      Ask FixBot
      • The ADF cable is routed through two cable guides.
      • Use a plastic opening tool to gently lift the guides to remove the cable.
      • Work carefully—the cable runs through tight channels that can break easily.
      Ask FixBot
      • The ADF unit is attached with two hinges (not screwed in).
      • Gently squeeze the clips on the hinges and lift off the ADF.
      Ask FixBot
      • Insert the new ADF unit into the clutch hinges and press it in until you hear it click into place.
      • Route the cable back through the guides and connect it correctly.
      Ask FixBot
      • Reinstall the rear top cover and the clutch hinge cover.
      • Reinstall the side covers.
      • Replace the front cover, as well as the ink compartment and maintenance unit cover.
      • Tighten all screws and check that all clips are engaged.
      Ask FixBot
      • Reconnect the device and power it on.
      • Perform a test scan with the ADF to ensure the document feeder is working.
      Ask FixBot
The ADF unit is now replaced and your printer is ready to use again. If the feed still does not work correctly, check the cable connection and the correct positioning of the ADF unit again.
KaiVi
978 Reputation
6 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 12
Past 30 Days: 117
All Time: 440
