Epson BrightLink 450wi Screen Replacement
    1. Epson BrightLink 450wi Screen Replacement, Speaker: step 1, image 1 of 3 Epson BrightLink 450wi Screen Replacement, Speaker: step 1, image 2 of 3 Epson BrightLink 450wi Screen Replacement, Speaker: step 1, image 3 of 3
      • Remove the 11 mm screws from the bottom of the device using a long-handle Phillips screwdriver.
      Ask FixBot
    2. Epson BrightLink 450wi Screen Replacement: step 2, image 1 of 3 Epson BrightLink 450wi Screen Replacement: step 2, image 2 of 3 Epson BrightLink 450wi Screen Replacement: step 2, image 3 of 3
      • Remove the 11 mm screws from the air filter section and power source section.
      Ask FixBot
    3. Epson BrightLink 450wi Screen Replacement: step 3, image 1 of 3 Epson BrightLink 450wi Screen Replacement: step 3, image 2 of 3 Epson BrightLink 450wi Screen Replacement: step 3, image 3 of 3
      Tool used on this step:
      Buy
      • Remove the 11 mm screws around the speaker. Use tweezers to move wires out of the way to locate screws.
      Ask FixBot
    4. Epson BrightLink 450wi Screen Replacement: step 4, image 1 of 2 Epson BrightLink 450wi Screen Replacement: step 4, image 2 of 2
      • Once the screws are removed, the speaker can be removed.
      Ask FixBot
    1. Epson BrightLink 450wi Screen Replacement, Screen: step 5, image 1 of 3 Epson BrightLink 450wi Screen Replacement, Screen: step 5, image 2 of 3 Epson BrightLink 450wi Screen Replacement, Screen: step 5, image 3 of 3
      • Using Phillips screwdriver unscrew the screws to the screen.
      Ask FixBot
    2. Epson BrightLink 450wi Screen Replacement: step 6, image 1 of 2 Epson BrightLink 450wi Screen Replacement: step 6, image 2 of 2
      • Gently lift the screen up after the screws are removed.
      Ask FixBot
    3. Epson BrightLink 450wi Screen Replacement: step 7, image 1 of 2 Epson BrightLink 450wi Screen Replacement: step 7, image 2 of 2
      Buy
      • Using the tweezers remove the wire to the back of the screen.
      Ask FixBot
Jason
257 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 19
All Time: 236
