Epson BrightLink 450wi Projector Lamp Replacement
View statistics:
Past 24 Hours:
2
Past 7 Days:
14
Past 30 Days:
51
All Time:
431
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 5 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
The lamp is the most important part of the Epson Brightlink 450Wi; it allows the image to be projected onto the screen by shining a light through the LCD system. Without a working lamp, your device is essentially useless; so it is very important to make sure your lamp is properly working.
For such an important part, it is luckily a replacement that just about anyone can perform. In the event your lamp isn't working right or when in need of replacement, follow this guide.
Tools
    1. Epson BrightLink 450wi Projector Lamp Replacement, Projector Lamp: step 1, image 1 of 2 Epson BrightLink 450wi Projector Lamp Replacement, Projector Lamp: step 1, image 2 of 2
      • Rotate Projector so you are looking at the right corner, next to the white EPSON logo.
      • On the right side, begin to unscrew the 11 mm screw.
      • The captive screw will not come out all the way, but will loosen enough for you to pull off the cover.
      Ask FixBot
    2. Epson BrightLink 450wi Projector Lamp Replacement: step 2, image 1 of 1
      • Once the screw is no longer tightened remove the cover plate by sliding it off towards the right of the device. This will expose the lamp.
      Ask FixBot
    3. Epson BrightLink 450wi Projector Lamp Replacement: step 3, image 1 of 2 Epson BrightLink 450wi Projector Lamp Replacement: step 3, image 2 of 2
      • Unscrew the two 11mm screws on the left of the lamp component.
      • These captive screws will also only unscrew enough to come loose but not to enough to be removed.
      Ask FixBot
    4. Epson BrightLink 450wi Projector Lamp Replacement: step 4, image 1 of 3 Epson BrightLink 450wi Projector Lamp Replacement: step 4, image 2 of 3 Epson BrightLink 450wi Projector Lamp Replacement: step 4, image 3 of 3
      • Once the screws are loose you can lift the thin metal handle upwards. Use it as leverage to pull the lamp straight out to remove it.
      Ask FixBot
Evan Sandoval
968 Reputation
7 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 14
Past 30 Days: 51
All Time: 431
