Up to 20% off select tools
Epomaker Shadow-X Switch Replacement
View statistics:
Past 24 Hours:
Past 7 Days:
11
Past 30 Days:
78
All Time:
675
Comments: 0
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 2 - 5 minutes
Difficulty: Easy
Tools
  • Spudger
    4.9
  • Phillips #00 Screwdriver
    4.9
Introduction
Go to step 1 ↓
Replacing the switches on your Epomaker Shadow-X can help restore or customize the typing experience. Follow this guide to safely remove and replace switches. Note: this process requires the keyboard to be hot-swappable.
    1. Epomaker Shadow-X Switch Replacement, Switch: step 1, image 1 of 2 Epomaker Shadow-X Switch Replacement, Switch: step 1, image 2 of 2
      • Unplug or disconnect the keyboard from the PC.
      • Turn off and unplug the keyboard if connected via USB-C.
      • If using Bluetooth, disconnect it from all paired devices.
      Ask FixBot
    2. Epomaker Shadow-X Switch Replacement: step 2, image 1 of 1
      • Use a keycap puller to remove each keycap over the switches you plan to replace.
      • Gently pull upward to avoid damaging the keycap or switch stem.
      Ask FixBot
    3. Epomaker Shadow-X Switch Replacement: step 3, image 1 of 1
      • Use a switch puller to press the clips on each side of the switch.
      • Gently pull the switch straight up to remove it from the socket.
      Ask FixBot
    4. Epomaker Shadow-X Switch Replacement: step 4, image 1 of 1
      • Align the pins of the new switch with the socket or PCB holes. Carefully press the switch into place until it clicks or fits snugly into the PCB.
      Ask FixBot
You’ve completed the switch replacement on your Epomaker Shadow-X keyboard! With new switches installed, your keyboard should offer an improved typing experience. Test each key to ensure they’re responsive, and enjoy the renewed feel of your keyboard.
2 other people completed this guide.
Author
with
Chase Fulsom
145 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 11
Past 30 Days: 78
All Time: 675
