Epomaker Shadow-X PCB Replacement
View statistics:
Past 24 Hours:
Past 7 Days:
16
Past 30 Days:
58
All Time:
662
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 15 - 20 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
The Printed Circuit Board (PCB) is a critical part of the keyboard, responsible for registering key presses and controlling LED functionality. Replacing the PCB may be necessary if there are issues with key registration or other electrical problems. Follow this guide to safely replace the PCB in your Epomaker Shadow-X.
Tools
    1. Epomaker Shadow-X PCB Replacement, PCB: step 1, image 1 of 1
      • Power off the keyboard and unplug any attached cables.
      • Place the keyboard on a clean, static-free workspace and wear an anti-static wrist strap if available.
      Ask FixBot
    2. Epomaker Shadow-X PCB Replacement: step 2, image 1 of 3 Epomaker Shadow-X PCB Replacement: step 2, image 2 of 3 Epomaker Shadow-X PCB Replacement: step 2, image 3 of 3
      • Use a keycap puller to remove all keycaps from the keyboard.
      • Remove all eight of the hex screws that secure the lower case.
      • Remove the lower case.
      Ask FixBot
    3. Epomaker Shadow-X PCB Replacement: step 3, image 1 of 1
      • Locate the PCB, which is mounted below the switch plate.
      • Disconnect any cables or connectors between the PCB and other components
      • Remove any screws or clips securing the PCB to the keyboard case. Carefully lift the PCB out of the case.
      • If there is adhesive or sticky residue holding it, gently work around the edges to release it without damaging components.
      Ask FixBot
    4. Epomaker Shadow-X PCB Replacement: step 4, image 1 of 1
      • Place the new PCB into the same position in the case, aligning all mounting holes and connectors.
      Ask FixBot
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 16
Past 30 Days: 58
All Time: 662
