Up to 20% off select tools
Epomaker Shadow-X Keycap Replacement
View statistics:
Past 24 Hours:
2
Past 7 Days:
20
Past 30 Days:
85
All Time:
620
Comments: 0
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 10 minutes
Difficulty: Easy
Tools
Introduction
Go to step 1 ↓
Use this guide to replace worn-out or damaged keycaps on the Epomaker Shadow-X mechanical keyboard, or to customize it with new keycaps. Keycap replacement is a straightforward process, and this guide will help ensure each step is done safely.
    1. Epomaker Shadow-X Keycap Replacement, Keycap: step 1, image 1 of 1
      • Power down the keyboard and unplug any attached cables.
      Ask FixBot
    2. Epomaker Shadow-X Keycap Replacement: step 2, image 1 of 1
      • Place the tool around the keycap, with the prongs on opposite sides of the key.
      • Gently pull the keycap up and off the switch stem.
      • Avoid pulling at an angle to prevent damaging the stem or keycap.
      Ask FixBot
    3. Epomaker Shadow-X Keycap Replacement: step 3, image 1 of 3 Epomaker Shadow-X Keycap Replacement: step 3, image 2 of 3 Epomaker Shadow-X Keycap Replacement: step 3, image 3 of 3
      • For larger keys, such as the Spacebar, Shift, or Enter, insert the puller evenly on both sides.
      • If using a pry tool, pry the middle first, then evenly on both sides.
      • Lift gently, using tweezers to stabilize any clips if necessary to prevent them from snapping.
      Ask FixBot
    4. Epomaker Shadow-X Keycap Replacement: step 4, image 1 of 3 Epomaker Shadow-X Keycap Replacement: step 4, image 2 of 3 Epomaker Shadow-X Keycap Replacement: step 4, image 3 of 3
      • Align the new keycaps, positioning the new keycaps over the switch stem, making sure it's centered.
      • Press straight down, applying even pressure until the keycap clicks into place.
      Ask FixBot
    5. Epomaker Shadow-X Keycap Replacement: step 5, image 1 of 2 Epomaker Shadow-X Keycap Replacement: step 5, image 2 of 2
      • Once all keycaps are installed, reconnect the keyboard to power and test each key for proper fit and function.
      Ask FixBot
You have successfully replaced the keycaps on your Epomaker Shadow-X keyboard! The new keycaps should enhance both the aesthetic and feel of your keyboard. Test each key to ensure they are securely attached and functioning smoothly, and enjoy the refreshed look of your setup.
2 other people completed this guide.
Author
with
Beck Spitler
611 Reputation
4 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 20
Past 30 Days: 85
All Time: 620
