Epiphone ES-335 PRO Pickguard Replacement
    1. Epiphone ES-335 PRO Pickguard Replacement, Pickguard: step 1, image 1 of 1
      • Locate the screw closest to the neck of the guitar.
      • Use a phillips head #2 screwdriver to completely unscrew the 1.0 mm length screw.
      • Be sure to keep any screws together as you will use them again, unless the replacement pickguard has its own screws.
      Ask FixBot
    2. Epiphone ES-335 PRO Pickguard Replacement: step 2, image 1 of 2 Epiphone ES-335 PRO Pickguard Replacement: step 2, image 2 of 2
      • Using a phillips head #2 screwdriver, completely unscrew the 1.0 mm length screw.
      • Gently lift the pickguard off the body of the guitar.
      Ask FixBot
1 Guide Comment
very nice and simple demo, but where would you get a new pickguard, as Epiphone will not
supply them and other aftermarket guards will not fit.
peterattard1 - Reply Share
Past 24 Hours: 1
Past 7 Days: 13
Past 30 Days: 57
All Time: 6,481
