Up to 20% off select tools
Engine air filter replacement
Views: 2.7K
View statistics:
Past 24 Hours:
3
Past 7 Days:
32
Past 30 Days:
134
All Time:
2,654
Comments: 0
Go to guide comments
Completed: 7
7 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 10 minutes
Difficulty: Easy
Community-Contributed Guide
Needs More Images
A few more images would make this guide's procedures crystal clear.
Introduction
Go to step 1 ↓
Applicable to all engines (H4D and H4Bt).
Replace every: 20,000km or year. It should be replaced earlier if driving in dusty environments.
A clogged engine air filter may impact fuel economy: it will create more resistance and therefore, increase the pumping losses.
Note: recommendations are given according to the French RTA's (Revue Technique Automobile) maintenance plan, matching Smart 453's maintenance plan in this case.
    1. Engine air filter replacement, Accessing the engine hood: step 1, image 1 of 1
      • Open the trunk.
      • Remove the trunk carpets.
      Ask FixBot
    2. Engine air filter replacement, Acessing the engine compartment: step 2, image 1 of 1
      • Unscrew the 6 screws by hand or with a T50 socket.
      • Lift and set aside the engine hood.
      Ask FixBot
    1. Engine air filter replacement, Disassembling the airbox: step 3, image 1 of 2 Engine air filter replacement, Disassembling the airbox: step 3, image 2 of 2
      • Unscrew the 2 Torx T25 screws.
      • Disglog the air filter lig by slightly pushing/pulling it forward then lifting it.
      Ask FixBot
      • Extract the used air filter.
      • Dust off the air box from any debris residing in it.
      • Optionnal but recommended: proceeed to a throttle body, MAP sensor and air manifold thermometer cleaning (see other tutorials).
      • Install the new air filter.
      Ask FixBot
    2. Engine air filter replacement, Reassembling the air box: step 5, image 1 of 2 Engine air filter replacement, Reassembling the air box: step 5, image 2 of 2
      • Replace the lid by sliding the two notches.
      • Screw back the two T25 Torx screws while maintaining a slight pression on the lid.
      Ask FixBot
Congratulations ! You replaced your engine air filter
7 other people completed this guide.
Special thanks to these translators:
fr en
100%
DocTwingo is helping us fix the world! Want to contribute?
Start translating ›
Author
with
DocTwingo
8,264 Reputation
31 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 32
Past 30 Days: 134
All Time: 2,654
