Engage Wired Optical Mouse Upper Board Removal
Views: 1.6K
View statistics:
Past 24 Hours:
2
Past 7 Days:
19
Past 30 Days:
91
All Time:
1,581
Comments: 5
5 comments on steps.
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 15 minutes
Difficulty: Easy
Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Needs More Images
A few more images would make this guide's procedures crystal clear.
Incorrect Tools
Help make this guide better by using the correct tools in images and/or text.
Better Introduction
Improve this guide by completing or revising its introduction.
Tools
  • Phillips #1 Screwdriver
    5
  • Spudger
    4.9
    1. Engage Wired Optical Mouse Upper Board Removal, Engage Wired Optical Mouse Top and Outer Shell Removal: step 1, image 1 of 1
      • Flip the mouse over and peel off the stickers on the perimeter of the bottom of the mouse.
      Ask FixBot
    2. Engage Wired Optical Mouse Upper Board Removal: step 2, image 1 of 1
      • Use the Phillips #1 screwdriver to remove four 5 mm screws from the bottom of the mouse.
      • Use the Phillips #1 screwdriver to remove the two 9 mm screws from the bottom of the mouse.
      Ask FixBot
    3. Engage Wired Optical Mouse Upper Board Removal: step 3, image 1 of 3 Engage Wired Optical Mouse Upper Board Removal: step 3, image 2 of 3 Engage Wired Optical Mouse Upper Board Removal: step 3, image 3 of 3
      • Grab the top shell of the mouse and lift up to remove.
      Ask FixBot
    4. Engage Wired Optical Mouse Upper Board Removal: step 4, image 1 of 1
      • The capacitors on this board can release stored electrical energy if touched.
      • Touch your capacitor discharge tool to the capacitor leads on the board to release the stored energy. If leads are inaccessible, wait until you've removed the board from the mouse body.
      Ask FixBot
    5. Engage Wired Optical Mouse Upper Board Removal: step 5, image 1 of 2 Engage Wired Optical Mouse Upper Board Removal: step 5, image 2 of 2
      • Use a spudger to pry underneath the white plug and pop it out to disconnect the upper board from the lower board.
      Ask FixBot
    1. Engage Wired Optical Mouse Upper Board Removal, Top Shell: step 6, image 1 of 1
      • Remove the 5 mm round head screw holding the middle piece to the top piece.
      • The outermost shell will now separate from the middle structure.
      Ask FixBot
    1. Engage Wired Optical Mouse Upper Board Removal, Upper Board: step 7, image 1 of 1
      • Using the Phillips #1 screwdriver, unscrew the 5 mm black flat head screw that's securing the scroll wheel cage.
      Ask FixBot
    2. Engage Wired Optical Mouse Upper Board Removal: step 8, image 1 of 2 Engage Wired Optical Mouse Upper Board Removal: step 8, image 2 of 2
      • Pinch the cage to release snaps. You can now pull the cage off.
      Ask FixBot
    3. Engage Wired Optical Mouse Upper Board Removal: step 9, image 1 of 1
      • Remove the screw holding the circuit board down.
      • The board will now pop off easily.
      Ask FixBot
2 other people completed this guide.
David
1,316 Reputation
4 Guides authored
Cal Poly, Team 18-36, Regan Winter 2013 Member of Cal Poly, Team 18-36, Regan Winter 2013
CPSU-REGAN-W13S18G36
3 Members
84 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 19
Past 30 Days: 91
All Time: 1,581
