Engage Wired Optical Mouse Top and Outer Shell Removal
  1. Engage Wired Optical Mouse Top and Outer Shell Removal, Engage Wired Optical Mouse Top and Outer Shell Removal: step 1, image 1 of 1
    • Flip the mouse over and peel off the stickers on the perimeter of the bottom of the mouse.
    Ask FixBot
  2. Engage Wired Optical Mouse Top and Outer Shell Removal: step 2, image 1 of 1
    • Use the Phillips #1 screwdriver to remove four 5 mm screws from the bottom of the mouse.
    • Use the Phillips #1 screwdriver to remove the two 9 mm screws from the bottom of the mouse.
    Ask FixBot
  3. Engage Wired Optical Mouse Top and Outer Shell Removal: step 3, image 1 of 3 Engage Wired Optical Mouse Top and Outer Shell Removal: step 3, image 2 of 3 Engage Wired Optical Mouse Top and Outer Shell Removal: step 3, image 3 of 3
    • Grab the top shell of the mouse and lift up to remove.
    Ask FixBot
  4. Engage Wired Optical Mouse Top and Outer Shell Removal: step 4, image 1 of 1
    • The capacitors on this board can release stored electrical energy if touched.
    • Touch your capacitor discharge tool to the capacitor leads on the board to release the stored energy. If leads are inaccessible, wait until you've removed the board from the mouse body.
    Ask FixBot
  5. Engage Wired Optical Mouse Top and Outer Shell Removal: step 5, image 1 of 2 Engage Wired Optical Mouse Top and Outer Shell Removal: step 5, image 2 of 2
    • Use a spudger to pry underneath the white plug and pop it out to disconnect the upper board from the lower board.
    Ask FixBot
2 other people completed this guide.
royceeklund
115 Reputation
3 Guides authored
Cal Poly, Team 18-36, Regan Winter 2013 Member of Cal Poly, Team 18-36, Regan Winter 2013
CPSU-REGAN-W13S18G36
3 Members
30 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 10
Past 30 Days: 38
All Time: 4,354
