Endgame Gear OP18K JST Cable Replacement
  1. Endgame Gear OP18K JST Cable Replacement, JST Cable: step 1, image 1 of 2 Endgame Gear OP18K JST Cable Replacement, JST Cable: step 1, image 2 of 2
    • Unplug the mouse before beginning.
    • Using a Phillips #00 screwdriver remove the two screws from the bottom of the mouse towards the rear.
    Ask FixBot
  2. Endgame Gear OP18K JST Cable Replacement: step 2, image 1 of 3 Endgame Gear OP18K JST Cable Replacement: step 2, image 2 of 3 Endgame Gear OP18K JST Cable Replacement: step 2, image 3 of 3
    • Pinch the back sides of the mouse and pry the small opening up.
    • Use the created opening to pull the rear of the mouse up.
    • Slightly push the top shell forward until the front of the mouse detaches from the base.
    • Be careful to not pull on the connected wires when detaching the top shell.
    Ask FixBot
  3. Endgame Gear OP18K JST Cable Replacement: step 3, image 1 of 3 Endgame Gear OP18K JST Cable Replacement: step 3, image 2 of 3 Endgame Gear OP18K JST Cable Replacement: step 3, image 3 of 3
    • Using your fingernails or a pair of tweezers wiggle out the three connectors.
    • Careful when disconnecting the wires; you may need to use a little force.
    Ask FixBot
  4. Endgame Gear OP18K JST Cable Replacement: step 4, image 1 of 3 Endgame Gear OP18K JST Cable Replacement: step 4, image 2 of 3 Endgame Gear OP18K JST Cable Replacement: step 4, image 3 of 3
    • Push the JST cable out of the stress relief by pushing it upwards.
    • Wiggle out the final large power connector at the back right of the circuit board.
    • Careful when disconnecting the power connector.
    Ask FixBot
  5. Endgame Gear OP18K JST Cable Replacement: step 5, image 1 of 3 Endgame Gear OP18K JST Cable Replacement: step 5, image 2 of 3 Endgame Gear OP18K JST Cable Replacement: step 5, image 3 of 3
    • Align the new cable connector and slot it into the power connection.
    • Set the stress relief of the cable into its spot in front of the scrollwheel.
    • Be sure the cable doesnt rest outside the shell and that the cable bends upward at the front.
    Ask FixBot
  6. Endgame Gear OP18K JST Cable Replacement: step 6, image 1 of 3 Endgame Gear OP18K JST Cable Replacement: step 6, image 2 of 3 Endgame Gear OP18K JST Cable Replacement: step 6, image 3 of 3
    • Align the three connectors and slot them into their places.
    • Be sure the wires are fully seated in and that the left and right front wires are connected in their proper spot.
    Ask FixBot
  7. Endgame Gear OP18K JST Cable Replacement: step 7, image 1 of 3 Endgame Gear OP18K JST Cable Replacement: step 7, image 2 of 3 Endgame Gear OP18K JST Cable Replacement: step 7, image 3 of 3
    • Push the top shell down and using a little pressure push the front bottom of the mouse to attach to the hooks.
    • Push on the bottom back of the mouse to close.
    • Be sure the wires dont block the mouse edges from closing
    Ask FixBot
  8. Endgame Gear OP18K JST Cable Replacement: step 8, image 1 of 2 Endgame Gear OP18K JST Cable Replacement: step 8, image 2 of 2
    • Put the bottom two screws back into their place using the Phillips #00 screwdriver.
    Ask FixBot
Finish Line
Isaac Sandoval
157 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 19
Past 30 Days: 103
All Time: 569
