Enabot EBO SE Wheels Replacement
  1. Enabot EBO SE Wheels Replacement, Wheel Assembly: step 1, image 1 of 1
    • Gently turn the robot upside down.
    • Place the robot on a stable surface to prevent it from rolling or falling.
    Ask FixBot
  2. Enabot EBO SE Wheels Replacement: step 2, image 1 of 3 Enabot EBO SE Wheels Replacement: step 2, image 2 of 3 Enabot EBO SE Wheels Replacement: step 2, image 3 of 3
    • Use a flathead 2.5 mm screwdriver to remove the 5.7 mm screw from the wheels.
    • A tool should have been provided in the box for this purpose.
    Ask FixBot
  3. Enabot EBO SE Wheels Replacement: step 3, image 1 of 2 Enabot EBO SE Wheels Replacement: step 3, image 2 of 2
    • Pull the wheel assembly towards you so it comes straight off without resistance.
    • If there is resistance, make sure to apply gentle force when pulling as it can get damaged with too much force.
    Ask FixBot
  4. Enabot EBO SE Wheels Replacement, Wheels: step 4, image 1 of 2 Enabot EBO SE Wheels Replacement, Wheels: step 4, image 2 of 2
    • Pull on the tire tread perpendicularly to the wheels to remove the tread.
    • The wheel should naturally come off with it for replacement.
    Ask FixBot
  5. Enabot EBO SE Wheels Replacement: step 5, image 1 of 2 Enabot EBO SE Wheels Replacement: step 5, image 2 of 2
    • Repeat previous step with the wheels on the other side.
    Ask FixBot
Kevin H.
716 Reputation
5 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 12
Past 30 Days: 51
All Time: 761
