Enabot EBO SE Lower Housing Replacement
    1. Enabot EBO SE Lower Housing Replacement, Wheel Assembly: step 1, image 1 of 1
      • Gently turn the robot upside down.
      • Place the robot on a stable surface to prevent it from rolling or falling.
      Ask FixBot
    2. Enabot EBO SE Lower Housing Replacement: step 2, image 1 of 3 Enabot EBO SE Lower Housing Replacement: step 2, image 2 of 3 Enabot EBO SE Lower Housing Replacement: step 2, image 3 of 3
      • Use a flathead 2.5 mm screwdriver to remove the 5.7 mm screw from the wheels.
      • A tool should have been provided in the box for this purpose.
      Ask FixBot
    3. Enabot EBO SE Lower Housing Replacement: step 3, image 1 of 2 Enabot EBO SE Lower Housing Replacement: step 3, image 2 of 2
      • Pull the wheel assembly towards you so it comes straight off without resistance.
      • If there is resistance, make sure to apply gentle force when pulling as it can get damaged with too much force.
      Ask FixBot
    1. Enabot EBO SE Lower Housing Replacement, Lower Housing: step 4, image 1 of 2 Enabot EBO SE Lower Housing Replacement, Lower Housing: step 4, image 2 of 2
      • Use a Torx screwdriver to remove the four 9 mm screws from the assembly.
      Ask FixBot
    2. Enabot EBO SE Lower Housing Replacement: step 5, image 1 of 3 Enabot EBO SE Lower Housing Replacement: step 5, image 2 of 3 Enabot EBO SE Lower Housing Replacement: step 5, image 3 of 3
      • Use your fingernail to carefully press down and eject the Micro SD Card from the back of the Enabot.
      • Keep the Micro SD Card in a safe spot for later.
      Ask FixBot
    3. Enabot EBO SE Lower Housing Replacement: step 6, image 1 of 2 Enabot EBO SE Lower Housing Replacement: step 6, image 2 of 2
      • Place the iFixit opening tool inside the Micro SD slot.
      • Very carefully apply pressure to the top of the slot and pry open the casing to separate the upper and lower housing.
      Ask FixBot
    4. Enabot EBO SE Lower Housing Replacement: step 7, image 1 of 3 Enabot EBO SE Lower Housing Replacement: step 7, image 2 of 3 Enabot EBO SE Lower Housing Replacement: step 7, image 3 of 3
      • Using the iFixit opening tool or your fingernail, place it underneath the gray tab on the lower housing.
      • Lift the tab up and pull out the ribbon cable to disconnect it from the lower housing.
      Ask FixBot
    5. Enabot EBO SE Lower Housing Replacement: step 8, image 1 of 3 Enabot EBO SE Lower Housing Replacement: step 8, image 2 of 3 Enabot EBO SE Lower Housing Replacement: step 8, image 3 of 3
      • There are two black and red wire connectors attached to the upper and lower housing.
      • Gently use your finger nails to lift up and disconnect both wires to fully separate the upper and lower housings.
      Ask FixBot
Kevin H.
716 Reputation
5 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 7
Past 30 Days: 51
All Time: 629
