Enabot EBO SE Camera Replacement
View statistics:
Past 24 Hours:
Past 7 Days:
13
Past 30 Days:
85
All Time:
784
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 5 - 10 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
Replacing your camera for the Enabot can be essential for your viewing experience. Your camera can severely impact your utilization of the Enabot EBO SE since you're viewing everything through the camera. Sometimes the camera can be dirty or not functioning properly leading to potential problems. In these following steps we will show you how to replace your camera.
Tools
    1. Enabot EBO SE Camera Replacement, Wheel Assembly: step 1, image 1 of 1
      • Gently turn the robot upside down.
      • Place the robot on a stable surface to prevent it from rolling or falling.
      Ask FixBot
    2. Enabot EBO SE Camera Replacement: step 2, image 1 of 3 Enabot EBO SE Camera Replacement: step 2, image 2 of 3 Enabot EBO SE Camera Replacement: step 2, image 3 of 3
      • Use a flathead 2.5 mm screwdriver to remove the 5.7 mm screw from the wheels.
      • A tool should have been provided in the box for this purpose.
      Ask FixBot
    3. Enabot EBO SE Camera Replacement: step 3, image 1 of 2 Enabot EBO SE Camera Replacement: step 3, image 2 of 2
      • Pull the wheel assembly towards you so it comes straight off without resistance.
      • If there is resistance, make sure to apply gentle force when pulling as it can get damaged with too much force.
      Ask FixBot
    1. Enabot EBO SE Camera Replacement, Lower Housing: step 4, image 1 of 2 Enabot EBO SE Camera Replacement, Lower Housing: step 4, image 2 of 2
      • Use a Torx screwdriver to remove the four 9 mm screws from the assembly.
      Ask FixBot
    2. Enabot EBO SE Camera Replacement: step 5, image 1 of 3 Enabot EBO SE Camera Replacement: step 5, image 2 of 3 Enabot EBO SE Camera Replacement: step 5, image 3 of 3
      • Use your fingernail to carefully press down and eject the Micro SD Card from the back of the Enabot.
      • Keep the Micro SD Card in a safe spot for later.
      Ask FixBot
    3. Enabot EBO SE Camera Replacement: step 6, image 1 of 2 Enabot EBO SE Camera Replacement: step 6, image 2 of 2
      • Place the iFixit opening tool inside the Micro SD slot.
      • Very carefully apply pressure to the top of the slot and pry open the casing to separate the upper and lower housing.
      Ask FixBot
    4. Enabot EBO SE Camera Replacement: step 7, image 1 of 3 Enabot EBO SE Camera Replacement: step 7, image 2 of 3 Enabot EBO SE Camera Replacement: step 7, image 3 of 3
      • Using the iFixit opening tool or your fingernail, place it underneath the gray tab on the lower housing.
      • Lift the tab up and pull out the ribbon cable to disconnect it from the lower housing.
      Ask FixBot
    5. Enabot EBO SE Camera Replacement: step 8, image 1 of 3 Enabot EBO SE Camera Replacement: step 8, image 2 of 3 Enabot EBO SE Camera Replacement: step 8, image 3 of 3
      • There are two black and red wire connectors attached to the upper and lower housing.
      • Gently use your finger nails to lift up and disconnect both wires to fully separate the upper and lower housings.
      Ask FixBot
    1. Enabot EBO SE Camera Replacement, Motherboard: step 9, image 1 of 2 Enabot EBO SE Camera Replacement, Motherboard: step 9, image 2 of 2
      • Use the iFixit opening tool to unlock the side gray tab and free the orange & black ribbon cable.
      Ask FixBot
    2. Enabot EBO SE Camera Replacement: step 10, image 1 of 2 Enabot EBO SE Camera Replacement: step 10, image 2 of 2
      • Use the iFixit opening tool to unlock the middle gray tab and free the orange & black ribbon cable.
      Ask FixBot
    3. Enabot EBO SE Camera Replacement: step 11, image 1 of 3 Enabot EBO SE Camera Replacement: step 11, image 2 of 3 Enabot EBO SE Camera Replacement: step 11, image 3 of 3
      • Select one of the release tabs on the edge of the upper casing that holds the motherboard in place.
      • Place one finger in between the motherboard and the upper casing.
      • Pull the release tab back while lifting the motherboard with your other finger to "pop" the motherboard out of the casing.
      Ask FixBot
    4. Enabot EBO SE Camera Replacement: step 12, image 1 of 3 Enabot EBO SE Camera Replacement: step 12, image 2 of 3 Enabot EBO SE Camera Replacement: step 12, image 3 of 3
      • Use the ifixit opening tool to disconnect the blue & white ribbon cable.
      • Gently pull the blue & white ribbon cable out of the gray connector tab.
      Ask FixBot
    1. Enabot EBO SE Camera Replacement, Camera: step 13, image 1 of 3 Enabot EBO SE Camera Replacement, Camera: step 13, image 2 of 3 Enabot EBO SE Camera Replacement, Camera: step 13, image 3 of 3
      • Use a Phillips #00 screwdriver to remove all five 7.4 mm screws from the upper casing.
      Ask FixBot
    2. Enabot EBO SE Camera Replacement: step 14, image 1 of 2 Enabot EBO SE Camera Replacement: step 14, image 2 of 2
      • Place your fingers in the space between the black casing and white lid.
      • Pull black casing towards you to separate the two parts.
      Ask FixBot
    3. Enabot EBO SE Camera Replacement: step 15, image 1 of 3 Enabot EBO SE Camera Replacement: step 15, image 2 of 3 Enabot EBO SE Camera Replacement: step 15, image 3 of 3
      • Remove the two 6 mm Phillips #00 screws on either side of the camera.
      Ask FixBot
    4. Enabot EBO SE Camera Replacement: step 16, image 1 of 3 Enabot EBO SE Camera Replacement: step 16, image 2 of 3 Enabot EBO SE Camera Replacement: step 16, image 3 of 3
      • Gently remove the camera until it comes out of the casing.
      Ask FixBot
Oscar Parra
109 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 13
Past 30 Days: 85
All Time: 784
