Emerson EM744 Motherboard Replacement
    1. Emerson EM744 Motherboard Replacement, Back Plate: step 1, image 1 of 1
      • Use a Phillips 00 bit to remove two 3mm screws from the bottom of the tablet.
      Ask FixBot
    2. Emerson EM744 Motherboard Replacement: step 2, image 1 of 3 Emerson EM744 Motherboard Replacement: step 2, image 2 of 3 Emerson EM744 Motherboard Replacement: step 2, image 3 of 3
      • Insert the nylon spudger into the bottom of the tablet, and gently slide it up the side.
      • Pull apart the two sides of the tablet, exposing the circuit board, battery, and other components of the tablet.
      Ask FixBot
    1. Emerson EM744 Motherboard Replacement, Motherboard: step 3, image 1 of 1
      • Use a Phillips 00 bit to remove 3 screws from the top of the tablet.
      Ask FixBot
    2. Emerson EM744 Motherboard Replacement: step 4, image 1 of 2 Emerson EM744 Motherboard Replacement: step 4, image 2 of 2
      • Disconnect three ribbon connectors from the circuit board with the nylon spudger.
      Ask FixBot
    3. Emerson EM744 Motherboard Replacement: step 5, image 1 of 1
      • Remove tape from the motherboard.
      Ask FixBot
    4. Emerson EM744 Motherboard Replacement: step 6, image 1 of 3 Emerson EM744 Motherboard Replacement: step 6, image 2 of 3 Emerson EM744 Motherboard Replacement: step 6, image 3 of 3
      • Desolder the positive (red) wire to the positive (+) lead, followed by desoldering the negative (black) wire to the negative lead.
      • Refer to the solder technique guide.
      Ask FixBot
Micalle Marin
267 Reputation
2 Guides authored
USF Tampa, Team 2-5, Blackwell Fall 2016 Member of USF Tampa, Team 2-5, Blackwell Fall 2016
USFT-BLACKWELL-F16S2G5
4 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 9
Past 30 Days: 25
All Time: 800
