Tools
Spudger4.9
Introduction
Go to step 1 ↓If the tablet has out of focus pictures or doesn't take them at all, this guide will show you how to replace the camera. Tools that are needed will include a Phillips Head screwdriver with a #00 3mm screw, spudger, plastic opening tool, as well as a pair of tweezers to properly remove the broken equipment.
Use a Phillips 00 bit to remove two 3mm screws from the bottom of the tablet.
Using the spudger to raise the zero insertion force (ZIF) connector to freely release the ribbon.
