Missing Steps
Oops! This guide is currently missing one or more important steps.
Tools
Introduction
Go to step 1 ↓If your Emerson ceiling fan is humming but the blades are not spinning, you most likely have a broken flywheel. It is a lot easier and cheaper to replace the flywheel yourself, rather than the whole fan.
Before using this guide, make sure you check to fan has power going to it. Check to make sure the circuit breaker is not flipped.
Replacing your flywheel is inexpensive and possible for most ceiling fan brands. If you do not know the brand of your fan, measure the flywheel once you remove it. Note the inside and outside diameter, and the locations and spaces between bracket and screw holes.
You will want to make sure power is turned off to the fan before you start to work on anything.
Use a Phillips #0 screwdriver to remove the ten 12.7 mm screws from the ceiling fan blades.
Open the switch housing using a Phillips #0 screwdriver to remove the three 7.9 mm screws.
Disconnect wires that are attached to the switch housing and the motor.
Slide the new flywheel into place making sure all the holes line up.
Place any wires through the same holes as they were before
Screw back on the three 7.9 mm screws to the switch housing using a Phillips #0 screwdriver.
Screw the light bulbs back in.
Using a Phillips #0 screwdriver, reconnect ceiling fan blades by re-screwing on ten 12.7 mm Phillip screws.
Test your fan. It should be running quietly with no problems. If something is wrong make sure to double check you hooked the wires up correctly.
2 other people completed this guide.
