Ematic eGlide 4 Wi-Fi Adaptor Replacement
View statistics:
Past 24 Hours:
3
Past 7 Days:
24
Past 30 Days:
91
All Time:
465
Comments: 0
Go to guide comments
Completed: 0
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 20 minutes
Difficulty: Moderate
Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
Introduction
Go to step 1 ↓
The Wi-Fi adaptor is a small antenna inside the tablet that allows the device to connect to wireless internet. The adaptor features its own circuit board, which will be necessary to exchange the part. The circuit board will be desoldered from the motherboard and the antenna will be removed from the front case.
Tools
    1. Ematic eGlide 4 Wi-Fi Adaptor Replacement, Rear Panel: step 1, image 1 of 1
      • Remove the 4.6mm Phillips #00 screw at the base of the device.
      Ask FixBot
    2. Ematic eGlide 4 Wi-Fi Adaptor Replacement: step 2, image 1 of 1
      • Slide the rear panel away from the base parallel to the screen.
      Ask FixBot
    3. Ematic eGlide 4 Wi-Fi Adaptor Replacement: step 3, image 1 of 2 Ematic eGlide 4 Wi-Fi Adaptor Replacement: step 3, image 2 of 2
      • Carefully remove the speakers from the rear panel.
      • Pull the speakers off of the rear panel.
      Ask FixBot
    1. Ematic eGlide 4 Wi-Fi Adaptor Replacement, Wi-Fi Adaptor: step 4, image 1 of 1
      Ask FixBot
    2. Ematic eGlide 4 Wi-Fi Adaptor Replacement: step 5, image 1 of 1
      • Gently pry the antenna out of the front case
      Ask FixBot
Bailey Hughes
617 Reputation
6 Guides authored
Baylor, Team 5-8, Williams Spring 2015 Member of Baylor, Team 5-8, Williams Spring 2015
BU-WILLIAMS-S15S5G8
3 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 24
Past 30 Days: 91
All Time: 465
